I dont know, what i’m doing wrong. I installed knxd and can make a connection to the bus via ip. If i try to switch on a light it works with
sudo knxtool groupswrite ip:192.168.0.6 3/0/0 1
192.168.0.6 is static ip of raspi. If I do with the multicast address it does not.
[11:40:04] openhabian@home:~$ sudo knxtool groupswrite ip:224.0.23.12 3/0/0 1
Open failed: Network is unreachable
so far, ok. If I define things I can find them in my PaperUI, just as defined in the knx.things. Everything looks GREEN. But from sitemap I cannt switch on and of. I always get
2020-10-30 11:39:32.019 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item '1BSchalter' for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
I already tried TUNNEL vs. ROUTER, Changed in sitemap the Capital letters from “Switch” to “switch”. Has anyone an idea please?
thx, Josef
- Platform information:
- Hardware: raspberry pi 2
- OS: Standard delivery
- openHAB version: 2
- Issue of the topic: Cannot obtain connection from openHAB to KNX
- Please post configurations (if applicable):
Bridge knx:ip:bridge [ // type="ROUTER", // ipAddress="224.0.23.12" , // localSourceAddr="0.0.0", // localIp="192.168.0.6" type="TUNNEL", ipAddress="192.168.0.62" , portNumber=3671, localSourceAddr="0.0.0", localIp="192.168.0.6", autoReconnectPeriod=1 ] { Thing device generic [ // fetch=true, pingInterval=300, readInterval=0 ] { Type switch : 1BSchalter "Steckdose" [ ga="1.001:3/0/0+<3/3/0" ] Type rollershutter : 1BRollo "Beschattung" [ upDown="1/0/3+1/6/3", stopMove="1/1/3" , position="1/6/3" ] Type number : 1BTemp "Raumtemperatur" [ga="2/2/7"] } }
- Items configuration related to the issue
switch 1BSchalter "Light [%s]" <light> { channel="knx:device:bridge:generic:1BSchalter" } rollershutter 1BRollo "Shade [%d %%]" <rollershutter> { channel="knx:device:bridge:generic:1BRollo" } number 1BTemp "Temperature [%.1f °C]" <temperature> { channel="knx:device:bridge:generic:1BTemp" }
- Sitemap configuration related to the issue
sitemap home label="Haus" { Frame label="Büro" { Switch item=1BSchalter Switch item=1BRollo Text item=1BTemp } }
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
2020-10-30 11:38:20.724 [me.event.ThingUpdatedEvent] - Thing ‘knx:ip:bridge’ has been updated.
2020-10-30 11:38:20.793 [me.event.ThingUpdatedEvent] - Thing ‘knx:device:bridge:generic’ has been updated.
2020-10-30 11:38:50.739 [hingStatusInfoChangedEvent] - ‘knx:ip:bridge’ changed from UNKNOWN to ONLINE
2020-10-30 11:38:50.747 [hingStatusInfoChangedEvent] - ‘knx:device:bridge:generic’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-10-30 11:39:31.977 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of ‘1BSchalter’org.eclipse.smarthome.core.items.ItemNotFoundException: Item ‘1BSchalter’ could not be found in the item registry
at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.getItem(ItemRegistryImpl.java:85) ~[?:?]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getItem(ItemUIRegistryImpl.java:837) ~[?:?]
at org.openhab.ui.basic.internal.render.SwitchRenderer.renderWidget(SwitchRenderer.java:84) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:194) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:160) [bundleFile:?]
