i’m connecting via IP towards ABB IP interface ( IPS/S3.1.1), here my knx.things
in the ETS5 it shows correct values are sent towards OH.
Bridge knx:ip:bridge [
ipAddress="192.168.1.2",
portnumber=3671,
localIp="192.168.1.12",
type="TUNNEL",
readingPause=100,
responseTimeout=40,
readRetriesLimit=10,
autoReconnectPeriod=80,
localSourceAddr="0.0.0"
Thing device generic[
Type switch : Zentraldimmer "Zentraldimmer" [ ga="<0/0/4" ]
Type switch : Beschattung1 "Beschattung1" [ ga="<0/0/6" ]
Type switch : Beschattung2 "Beschattung2" [ ga="<0/0/7" ]
Type switch : All_Lights "Haus" [ ga="<0/0/3" ]
Type switch : Wallbox_1 "Wallbox_1" [ ga="<0/0/24" ]
Type switch : Wallbox_3 "Wallbox_3" [ ga="<0/0/25" ]
Type switch : RegenAlarm "Regen" [ ga="<0/0/26" ]
Type switch : Light_KG_Flur_Decke "Flur Keller Decke" [ ga="<1/0/100" ]
Type switch : Light_KG_Buero_Decke "Buerolicht" [ ga="<1/0/112" ]
Type switch : Light_KG_Dusche "Dusche" [ ga="<1/0/113" ]
Type switch : Light_KG_Waschkeller_Decke "Waschkeller" [ ga="<1/0/130" ]
Type switch : Light_KG_Regal_Decke "Regal" [ ga="<1/0/111" ]
Type switch : Light_KG_Vorrat_Decke "Vorrat" [ ga="<1/0/120" ]
// Type switch : Light_EG_Wohnzimmer_White "Wohnzimmerlicht" [ ga="<1/0/221" ]
// Type switch : Light_EG_Esszimmer "Esszimmerlicht" [ ga="<1/0/220" ]
// Type switch : Light_EG_Esszimmer_Tisch "Esszimmer Tisch" [ ga="<1/0/226" ]
Type switch : Light_EG_Wohnzimmer_Rainbow "Regenbogen" [ ga="<12/0/227" ]
Type switch : Light_EG_Terrasse_Mauer "Gartenbeleuchtung" [ ga="<1/0/230" ]
Type switch : Light_EG_Terrasse_Markise "Lichterkette" [ ga="<1/0/231" ]
Type switch : Light_EG_Kueche_Decke "Küche Arbeitsplatte" [ ga="<1/0/252" ]
Type switch : Light_EG_Kueche_Table "Kueche Tisch" [ ga="<1/0/251" ]
Type switch : Light_EG_Flur_Garderobe "EG Flur" [ ga="<1/0/210" ]
Type switch : Light_EG_GaesteWc_Decke "EG GasteWc" [ ga="<1/0/240" ]
Type switch : Light_EG_Tueroeffner "Türöffner Hoftor" [ ga="<0/0/15" ]
Type switch : Haustuer_entriegeln "Haustuer entriegeln" [ ga="<0/0/12" ]
Type switch : Light_OG_Bad_Decke "Badezimmer" [ ga="<1/0/136" ]
Type switch : Light_OG_Flur_Decke "OG Flur" [ ga="<1/0/54" ]
// Type switch : Light_OG_Emelie_Decke "OG Licht Emelie" [ ga="<1/0/114" ]
// Type switch : Light_OG_Jonathan_Decke "Licht" [ ga="<1/0/104" ]
Type switch : Light_Schlafzimmer_Decke "Schlafzimmerlicht" [ ga="<1/0/125" ]
Type switch : Light_Hoflicht "Hoflicht Eingang" [ ga="<0/0/8" ]
Type switch : Nachtabschaltung_Jonathan "Nachtabschaltung Jonathan" [ ga="<0/0/16" ]
Type switch : Nachtabschaltung_Emelie "Nachtabschaltung Emelie" [ ga="<0/0/17" ]
Type switch : Nachtabschaltung_Schlafzimmer "Nachtabschaltung Schlafzimmer" [ ga="<0/0/18" ]
Type switch : Shutter_EG_Wohnzimmer_Markise "Markise" [ ga="<5/0/227" ]
Type switch : Shutter_EG_Wohnzimmer_Markise1 "Markise 50%" [ ga="<5/0/228" ]
Type switch : Leinwand_Unten "Rolladen EG Wohnzimmer Leinwand unten" [ ga="<12/0/222" ]
Type switch : Bewegung_KG_Treppe "Bewegungsmelder KG Treppe" [ ga="<11/0/20" ]
Type switch : Bewegung_EG_Flur "Bewegungsmelder EG Flur" [ ga="<11/0/21" ]
Type switch : Bewegung_OG_Flur "Bewegungsmelder OG Flur" [ ga="<11/0/22" ]
Type switch : Bewegung_EG_WC "Bewegungsmelder EG WC" [ ga="<11/0/23" ]
Type switch : Bewegung_OG_Bad "Bewegungsmelder OG Bad" [ ga="<11/0/24" ]
Type switch : Bewegung_OG_Bad_Dusche "Bewegungsmelder OG Bad Dusche" [ ga="<11/0/26" ]
Type switch : Bewegung_KG_Buero "Bewegungsmelder KG Buero" [ ga="<11/0/25" ]
Type switch : Bewegung_EG_Kueche "Bewegungsmelder EG Küche" [ ga="<11/0/27" ]
Type switch : Alarm_Drainage "Alarm Drainagepumpe defekt" [ ga="<9/0/0" ]
Type switch : Nachtabsenkung "Heizung Nachtabsenkung" [ ga="<8/0/17" ]
Type switch : Nachtabsenkung1 "Heizung Nachtabsenkung1" [ ga="<8/0/28" ]
Type switch : Komforttemperatur "Komfortemperatur" [ ga="<8/0/18" ]
Type switch : WW_Zirkulation "Warmwasser Zirkulation" [ ga="<8/0/13" ]
Type switch : Helligkeit1 "Dach Helligkeitswert 1 Licht" [ ga="<0/0/20" ]
Type switch : Helligkeit2 "Dach Helligkeitswert 2 Licht" [ ga="<0/0/21" ]
Type switch : HelligkeitRollo "Dach Helligkeitswert Rollo" [ ga="<0/0/1" ]
Type switch : Haustuer_Relais_auf "Haustür Relais auf [MAP(de.map):%s]" [ ga="<14/0/1" ]
Type switch : Haustuer_Relais_zu "Haustür Relais zu [MAP(de.map):%s]" [ ga="<14/0/0" ]
Type switch : Haustuer_Relais_tueroeffner "Haustür Relais Türöffner [MAP(de.map):%s]" [ ga="<14/0/2" ]
Type switch : Haustuer_Klingel "Haustür Klingel [MAP(de.map):%s]" [ ga="<11/0/15" ]
Type switch : Kueche_Alexa "Küche + Alexa [MAP(de.map):%s]" [ ga="<0/0/23" ]
Type switch : Heizung_KG "Heizung KG schalten[MAP(hz.map):%s]" [ ga="<8/0/0" ]
Type switch : Heizung_Schlafzimmer "Heizung Schlafzimmer schalten[MAP(hz.map):%s]" [ ga="<8/0/2" ]
Type switch : TagNacht "TagNacht" [ ga="<7/0/0" ]
Type dimmer : Light_EG_Wohnzimmer_White_dim "Dimmer Weiss [%d %%]" [ switch="1/0/221+<2/4/221", position="5.001:2/2/221+<2/3/221", increaseDecrease="2/0/221+<2/3/221" , frequency=300 ]
Type dimmer : Light_EG_Wohnzimmer_Red "Rot [%d %%]" [ switch="1/0/222+<2/4/222", position="5.001:2/2/222+<2/3/222", increaseDecrease="2/0/222+<2/3/222" , frequency=300 ]
Type dimmer : Light_EG_Wohnzimmer_Green "Grün [%d %%]" [ switch="1/0/223+<2/4/223", position="5.001:2/2/223+<2/3/223", increaseDecrease="2/0/223+<2/3/223" , frequency=300 ]
Type dimmer : Light_EG_Wohnzimmer_Blue "Blau [%d %%]" [ switch="1/0/224+<2/4/224", position="5.001:2/2/224+<2/3/224", increaseDecrease="2/0/224+<2/3/224" , frequency=300 ]
Type dimmer : Light_EG_Wohnzimmer_Decke "Esszimmer [%d %%]" [ switch="1/0/220+<2/4/220", position="5.001:2/2/220+<2/3/220", increaseDecrease="2/0/220+<2/3/220" , frequency=300 ]
Type dimmer : Light_EG_Wohnzimmer_Tisch "Esszimmer Tisch [%d %%]" [ switch="1/0/226+<2/4/225", position="5.001:2/2/225+<2/3/225", increaseDecrease="2/0/225+<2/3/225" , frequency=300 ]
Type dimmer : Light_OG_Emelie_Decke_Dim "Dimmer Emelie [%d %%]" [ switch="1/0/114+<2/4/114", position="5.001:2/2/114+<2/3/114", increaseDecrease="2/0/114+<2/3/114" , frequency=300 ]
Type dimmer : Light_OG_Jonathan_Decke_Dim "Dimmer Jonathan [%d %%]" [ switch="1/0/104+<2/4/104", position="5.001:2/2/104+<2/3/104", increaseDecrease="2/0/104+<2/3/104" , frequency=300 ]
Type rollershutter : Shutter_EG_GaesteWc "Rolladen WC [%d %%]" [ upDown="3/0/245", stopMove="4/0/245", position="5.001:5/0/245+<6/0/245" ]
Type rollershutter : Shutter_EG_Kueche "Rolladen Küche[%d %%]" [ upDown="3/0/255", stopMove="4/0/255", position="5.001:5/0/255+<6/0/255" ]
Type rollershutter : Shutter_EG_Wohnzimmer_Fenster "Rolladen Wohnzimmer Fenster[%d %%]" [ upDown="3/0/226", stopMove="4/0/226", position="5.001:5/0/226+<6/0/226" ]
Type rollershutter : Shutter_EG_Wohnzimmer_Terrasse "Rolladen Wohnzimmer Terasse[%d %%]" [ upDown="3/0/225", stopMove="4/0/225", position="5.001:5/0/225+<6/0/225" ]
Type rollershutter : Shutter_OG_Schlafzimmer "Rolladen Schlafzimmer[%d %%]" [ upDown="3/0/129", stopMove="4/0/129", position="5.001:5/0/129+<6/0/129" ]
Type rollershutter : Shutter_OG_Bad "Rolladen Bad [%d %%]" [ upDown="3/0/139", stopMove="4/0/239", position="5.001:5/0/139+<6/0/139" ]
Type rollershutter : Shutter_OG_Emelie "Rolladen Emelie[%d %%]" [ upDown="3/0/119", stopMove="4/0/119", position="5.001:5/0/119+<6/0/119" ]
Type rollershutter : Shutter_OG_Jonathan "Rolladen Jonathan [%d %%]" [ upDown="3/0/109", stopMove="4/0/109", position="5.001:5/0/109+<6/0/109" ]
Type rollershutter : Shutter_OG_Dachfenster_Schlafen "Dachfenster Schlafen [%d %%]" [ upDown="3/0/130", stopMove="4/0/130", position="5.001:5/0/130+<6/0/130" ]
Type rollershutter : Shutter_OG_Dachfenster_Bad "Dachfenster Bad [%d %%]" [ upDown="3/0/140", stopMove="4/0/140", position="5.001:5/0/140+<6/0/140" ]
Type contact : Door_EG_Eingangstuer "Eingangstür [MAP(de.map):%s]" [ ga="<11/0/1" ]
Type contact : Door_EG_WC "WC Tür [MAP(de.map):%s]" [ ga="<11/0/18" ]
Type contact : Door_EG_Terrassentuer "Terassentür [MAP(en.map):%s]" [ ga="<11/0/3" ]
Type contact : Door_OG_Badzimmertuer "Badezimmertuer [MAP(de.map):%s]" [ ga="<11/0/16" ]
Type contact : Door_OG_Badzimmertuer_Alexa "Badezimmertuer Alexa [MAP(de.map):%s]" [ ga="<11/0/17" ]
Type contact : Window_EG_Kueche "Fenster Küche [MAP(en.map):%s]" [ ga="<11/0/2" ]
Type contact : Window_EG_Wohnzimmer "Fenster Wohnzimmer [MAP(en.map):%s]" [ ga="<11/0/0" ]
Type contact : Window_EG_GaesteWc "Fenster Gäste WC [MAP(en.map):%s]" [ ga="<11/0/5" ]
Type contact : Window_OG_Bad "Fenster OG Bad [MAP(en.map):%s]" [ ga="<11/0/8" ]
Type contact : Window_OG_Schlafzimmer "Fenster OG Schlafzimmer [MAP(en.map):%s]" [ ga="<11/0/9" ]
Type contact : Window_OG_Emelie_Window "Fenster Emelie [MAP(en.map):%s]" [ ga="<11/0/10" ]
Type contact : Window_OG_Jonathan_Window "Fenster Jonathan [MAP(en.map):%s]" [ ga="<11/0/11" ]
Type switch : Window_OG_Schlafen_Dachfenster "Dachfenster Schlafen [MAP(en.map):%s]" [ ga="<11/0/12" ]
Type switch : Window_OG_Bad_Dachfenster "Dachfenster Bad [MAP(en.map):%s]" [ ga="<11/0/13" ]
Type contact : Heating_KG "Heizung KG [MAP(hz.map):%s]" [ ga="<8/0/0" ]
Type contact : Heating_EG "Heizung EG [MAP(hz.map):%s]" [ ga="<8/0/15" ]
Type contact : Heating_OG_Bad "Heizung OG Bad [MAP(hz.map):%s]" [ ga="<8/0/16" ]
Type contact : Heating_OG_Emelie "Heizung OG Emelie [MAP(hz.map):%s]" [ ga="<8/0/25" ]
Type contact : Heating_OG_Schlafen "Heizung OG Schlafen [MAP(hz.map):%s]" [ ga="<8/0/2" ]
Type contact : Heating_OG_Jonathan "Heizung OG Jonathan[MAP(hz.map):%s]" [ ga="<8/0/27" ]
Type number : Temperatur_EG_Wohnzimmer "Temperatur Wohnzimmer [%.1f °C]" [ ga="8/0/13" ]
Type number : Temperatur_OG_Bad "Temperatur OG Bad [%.1f °C]" [ ga="8/0/14" ]
Type number : Temperatur_OG_Emelie "Temperatur OG Emelie [%.1f °C]" [ ga="8/0/22" ]
Type number : Temperatur_OG_Schlafen "Temperatur OG Schlafen [%.1f °C]" [ ga="8/0/24" ]
Type number : Temperatur_OG_Jonathan "Temperatur OG Jonathan [%.1f °C]" [ ga="8/0/23" ]
Type number : Solltemp_KG "Solltemperatur KG [%.1f °C]" [ ga="8/0/12" ]
Type number : Solltemp_EG "Solltemperatur EG [%.1f °C]" [ ga="8/0/12" ]
Type number : Solltemp_OG "Solltemperatur OG [%.1f °C]" [ ga="8/0/11" ]
Type number : Temperatur_OG_Schlafen_Soll "Solltemperatur Schlafen [%.1f °C]" [ ga="8/0/21" ]
Type datetime-control : TimeKNX "Uhrzeit" [ ga="10.001:7/0/2" ]
Type datetime-control : wochenzeit "Zeit und Tag" [ ga="10.001:7/0/2" ]
Type datetime-control : Datum "Datum" [ ga="19.001:7/0/3" ]
Type number : Helligkeit_vorne "Helligkeit vorne [%.1f Lux]" [ ga="15/0/0" ]
Type number : Helligkeit_rechts "Helligkeit rechts [%.1f Lux]" [ ga="15/0/1" ]
Type number : Helligkeit_links "Helligkeit links [%.1f Lux]" [ ga="15/0/2" ]
Type number : Maximale_Helligkeit "Maximale Helligkeit [%.1f Lux]" [ ga="15/0/3" ]
Type number : Aussentemperatur "Aussentemperatur [%.1f °C]" [ ga="15/0/4" ]
Type number : Windgeschwindigkeit "Windgeschwindigkeit [%.1f m/s]" [ ga="15/0/5" ]
Type contact : Regen_Sensor "Regen Sensor " [ ga="15/0/6" ]
Type datetime-control : Lokale_Zeit "Uhrzeit" [ ga="15/0/8" ]
Type datetime-control : Lokale_Datum "Datum" [ ga="15/0/9" ]
Type switch : Zeit_anfragen "Zeit anfragen" [ ga="15/0/10" ]
Type contact : Temperatursensor_Status "Temperatursensor Status" [ ga="15/0/15" ]
Type number : Elevation "Elevation [%.1f °C]" [ ga="15/0/12" ]
Type number : Azimut "Azimut [%.1f °C]" [ ga="15/0/13" ]
Type contact : Wetterstation_C1_Schalten "Universal Kanal C1.1 Schalten" [ ga="15/0/20" ]
Type number : Wetterstation_C1_Schwellwert "Universal Kanal Schwellwert [%.1f °C]" [ ga="15/0/23" ]
items
Switch All_Lights "Haus [MAP(de.map):%s]" <light> [ "Switchable" ] { channel="knx:device:bridge:generic:All_Lights", autoupdate="true" }
Switch Zentraldimmer "Zentraldimmer [MAP(de.map):%s]" <light> { channel="knx:device:bridge:generic:Zentraldimmer", autoupdate="true" }
Switch Wallbox_1 "Wallbox mit 1 Phase [MAP(de.map):%s]" <light> (Tesla) { channel="knx:device:bridge:generic:Wallbox_1", autoupdate="true" }
Switch Wallbox_3 "Wallbox mit 3 Phasen [MAP(de.map):%s]" <light> (Tesla) { channel="knx:device:bridge:generic:Wallbox_3", autoupdate="true" }
Switch RegenAlarm "Regen [MAP(de.map):%s]" <light> (Status) [ "Switchable" ] { channel="knx:device:bridge:generic:RegenAlarm", autoupdate="true" }
Switch Beschattung1 "Beschattung vorne [MAP(de.map):%s]" <light> [ "Switchable" ] { channel="knx:device:bridge:generic:Beschattung1", autoupdate="true" }
Switch Beschattung2 "Beschattung hinten [MAP(de.map):%s]" <light> [ "Switchable" ] { channel="knx:device:bridge:generic:Beschattung2", autoupdate="true" }
Switch Light_KG_Flur_Decke "Flur Keller Decke [MAP(de.map):%s]" <light> (AlleLichter) { channel="knx:device:bridge:generic:Light_KG_Flur_Decke", autoupdate="true" }
Switch Light_KG_Buero_Decke "Bürolicht [MAP(de.map):%s]" <light> (KG_Buero,AlleLichter) { channel="knx:device:bridge:generic:Light_KG_Buero_Decke", autoupdate="true" }
Switch Light_KG_Dusche "Dusche [MAP(de.map):%s]" <light> (KG_Buero,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_KG_Dusche", autoupdate="true" }
Switch Light_KG_Waschkeller_Decke "Waschkeller [MAP(de.map):%s]" <light> (KG_Waschkueche,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_KG_Waschkeller_Decke", autoupdate="true" }
Switch Light_KG_Regal_Decke "Regal [MAP(de.map):%s]" <light> (KG_Regal,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_KG_Regal_Decke", autoupdate="true" }
Switch Light_KG_Vorrat_Decke "Vorrat [MAP(de.map):%s]" <light> (KG_Vorrat,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_KG_Vorrat_Decke", autoupdate="true" }
//Switch Light_EG_Wohnzimmer_White "Wohnzimmerlicht [MAP(de.map):%s]" <light> (EG_Wohnzimmer,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_White", autoupdate="true" }
Switch Light_EG_Esszimmer "Esszimmerlicht [MAP(de.map):%s]" <light> (EG_Wohnzimmer,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_Esszimmer", autoupdate="true" }
Switch Light_EG_Esszimmer_Tisch "Esszimmer Tisch [MAP(de.map):%s]" <light> (EG_Wohnzimmer,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_Esszimmer_Tisch", autoupdate="true" }
Switch Light_EG_Wohnzimmer_Rainbow "Regenbogen [MAP(de.map):%s]" <light> (EG_Wohnzimmer,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Rainbow", autoupdate="true" }
Switch Light_EG_Terrasse_Mauer "Gartenbeleuchtung [MAP(de.map):%s]" <light> (EG_Terrasse,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_Terrasse_Mauer", autoupdate="true" }
Switch Light_EG_Terrasse_Markise "Strom Terrasse [MAP(de.map):%s]" <light> (EG_Terrasse,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_Terrasse_Markise", autoupdate="true" }
Switch Light_EG_Kueche_Decke "Küche Arbeitsplatte [MAP(de.map):%s]" <light> (EG_Kueche,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_Kueche_Decke", autoupdate="true" }
Switch Light_EG_Kueche_Table "Küche Tisch [MAP(de.map):%s]" <light> (EG_Kueche,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_Kueche_Table", autoupdate="true" }
Switch Light_EG_Flur_Garderobe "I Strom Beleuchtung EG Flur[MAP(de.map):%s]" (EG_Flur) { channel="knx:device:bridge:generic:Light_EG_Flur_Garderobe", autoupdate="true" }
Switch Light_EG_GaesteWc_Decke "GästeWc [MAP(de.map):%s]" <light> (EG_GaesteWc,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_EG_GaesteWc_Decke", autoupdate="true" }
Switch Light_EG_Tueroeffner "Türöffner [MAP(de.map):%s]" (EG_Tueroeffner) { channel="knx:device:bridge:generic:Light_EG_Tueroeffner", autoupdate="true" }
Switch Haustuer_entriegeln "Haustür entriegeln [MAP(de.map):%s]" (EG_Tueroeffner) { channel="knx:device:bridge:generic:Haustuer_entriegeln", autoupdate="true" }
Switch Light_OG_Bad_Decke "I Badezimmer [MAP(de.map):%s]" <light> (OG_Bad) { channel="knx:device:bridge:generic:Light_OG_Bad_Decke", autoupdate="true" }
Switch Light_OG_Flur_Decke "I OG Flur [MAP(de.map):%s]" <light> (OG_Flur) { channel="knx:device:bridge:generic:Light_OG_Flur_Decke", autoupdate="true" }
Switch Light_OG_Emelie_Decke "Emelie Licht [MAP(de.map):%s]" <light> (OG_Emelie,AlleLichter) { channel="knx:device:bridge:generic:Light_OG_Emelie_Decke", autoupdate="true" }
Switch Light_OG_Jonathan_Decke "Jonathan Licht [MAP(de.map):%s]" <light> (OG_Jonathan,AlleLichter) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_OG_Jonathan_Decke", autoupdate="true", homekit="Switchable" }
Switch Light_Schlafzimmer_Decke "Schlafzimmerlicht [MAP(de.map):%s]" <light> (OG_Schlafzimmer,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_Schlafzimmer_Decke", autoupdate="true" }
Switch Light_Hoflicht "Hoflicht Eingang [MAP(de.map):%s]" <light> (EG_Flur) [ "Switchable" ] { channel="knx:device:bridge:generic:Light_Hoflicht", autoupdate="true" }
Switch Nachtabschaltung_Jonathan "Nachtabschaltung Jonathan [MAP(de.map):%s]" <light> (OG_Schlafzimmer, OG_Jonathan) [ "Switchable" ] { channel="knx:device:bridge:generic:Nachtabschaltung_Jonathan", autoupdate="true", homekit="Switchable" }
Switch Nachtabschaltung_Emelie "Nachtabschaltung Emelie [MAP(de.map):%s]" <light> (OG_Schlafzimmer, OG_Emelie) [ "Switchable" ] { channel="knx:device:bridge:generic:Nachtabschaltung_Emelie", autoupdate="true" }
Switch Nachtabschaltung_Schlafzimmer "Nachtabschaltung Schlafzimmer [MAP(de.map):%s]" <light> (OG_Schlafzimmer) [ "Switchable" ] { channel="knx:device:bridge:generic:Nachtabschaltung_Schlafzimmer", autoupdate="true" }
Switch Shutter_EG_Wohnzimmer_Markise "Markise [MAP(de.map):%s]" (EG_Terrasse, Rollaeden) [ "Switchable" ] { channel="knx:device:bridge:generic:Shutter_EG_Wohnzimmer_Markise", autoupdate="true" }
Switch Shutter_EG_Wohnzimmer_Markise1 "Markise 50% [MAP(de.map):%s]" (EG_Terrasse, Rollaeden) [ "Switchable" ] { channel="knx:device:bridge:generic:Shutter_EG_Wohnzimmer_Markise1", autoupdate="true" }
Switch Leinwand_Unten "Rolladen EG Wohnzimmer Leinwand unten [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Leinwand_Unten", autoupdate="true" }
Switch Bewegung_KG_Treppe "Bewegungsmelder KG Treppe [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Bewegung_KG_Treppe", autoupdate="true" }
Switch Bewegung_EG_Flur "Bewegungsmelder EG Flur [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Bewegung_EG_Flur", autoupdate="true" }
Switch Bewegung_OG_Flur "Bewegungsmelder OG Flur [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Bewegung_OG_Flur", autoupdate="true" }
Switch Bewegung_EG_WC "Bewegungsmelder EG WC [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Bewegung_EG_WC", autoupdate="true" }
Switch Bewegung_OG_Bad "Bewegungsmelder OG Bad [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Bewegung_OG_Bad", autoupdate="true" }
Switch Bewegung_OG_Bad_Dusche "Bewegungsmelder OG Bad Dusche [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Bewegung_OG_Bad_Dusche", autoupdate="true" }
Switch Bewegung_KG_Buero "Bewegungsmelder KG Büro [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Bewegung_KG_Buero", autoupdate="true" }
Switch Bewegung_EG_Kueche "Bewegungsmelder EG Küche [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Bewegung_EG_Kueche", autoupdate="true" }
Switch Alarm_Drainage "Alarm Drainagepumpe defekt [MAP(de.map):%s]" (Status) { channel="knx:device:bridge:generic:Alarm_Drainage", autoupdate="true" }
Switch Nachtabsenkung "Heizung Nachtabsenkung [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Nachtabsenkung", autoupdate="true" }
Switch Nachtabsenkung1 "Heizung Nachtabsenkung [MAP(de.map):%s]" (OG_Jonathan) { channel="knx:device:bridge:generic:Nachtabsenkung1", autoupdate="true" }
Switch Komforttemperatur "Komfortemperatur [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Komforttemperatur", autoupdate="true" }
Switch WW_Zirkulation "Warmwasser Zirkulation [MAP(de.map):%s]" { channel="knx:device:bridge:generic:WW_Zirkulation", autoupdate="true" }
Switch Helligkeit1 "Dach Helligkeitswert 1 Licht [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Helligkeit1", autoupdate="true" }
Switch Helligkeit2 "Dach Helligkeitswert 2 Licht [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Helligkeit2", autoupdate="true" }
Switch HelligkeitRollo "Dach Helligkeitswert Rollo [MAP(de.map):%s]" { channel="knx:device:bridge:generic:HelligkeitRollo", autoupdate="true" }
Switch SteckdoseTv "Steckdose TV [MAP(de.map):%s]" { channel="knx:device:bridge:generic:SteckdoseTv", autoupdate="true" }
Switch Haustuer_Relais_auf "Haustür Relais auf [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Haustuer_Relais_auf", autoupdate="true" }
Switch Haustuer_Relais_zu "Haustür Relais zu [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Haustuer_Relais_zu", autoupdate="true" }
Switch Haustuer_Relais_tueroeffner "Haustür Relais Türöffner [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Haustuer_Relais_tueroeffner", autoupdate="true" }
Switch Haustuer_Klingel "Haustür Klingel [MAP(de.map):%s]" { channel="knx:device:bridge:generic:Haustuer_Klingel", autoupdate="true" }
Switch Kueche_Alexa "Küche + Alexa [MAP(de.map):%s]" (EG_Kueche) { channel="knx:device:bridge:generic:Kueche_Alexa", autoupdate="true" }
Switch Heizung_KG "Heizung KG schalten[MAP(de.map):%s]" (KG) { channel="knx:device:bridge:generic:Heizung_KG", autoupdate="true" }
Switch Heizung_Schlafzimmer "Heizung Schlafzimmer schalten[MAP(de.map):%s]" (OG_Schlafzimmer) { channel="knx:device:bridge:generic:Heizung_Schlafzimmer", autoupdate="true" }
Switch TagNacht "TagNacht" (Status) { channel="knx:device:bridge:generic:TagNacht", autoupdate="true" }
Dimmer Light_EG_Wohnzimmer_White_dim "Wohnzimmerlicht [%d %%]" (EG_Wohnzimmer,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_White_dim", autoupdate="true" }
Dimmer Light_EG_Wohnzimmer_Red "Dimmer Rot [%d %%]" (EG_Wohnzimmer,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Red", autoupdate="true" }
Dimmer Light_EG_Wohnzimmer_Green "Dimmer Grün [%d %%]" (EG_Wohnzimmer,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Green", autoupdate="true" }
Dimmer Light_EG_Wohnzimmer_Blue "Dimmer Blau [%d %%]" (EG_Wohnzimmer,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Blue", autoupdate="true" }
Dimmer Light_EG_Wohnzimmer_Decke "Dimmer Esszimmer [%d %%]" (EG_Wohnzimmer,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Decke", autoupdate="true" }
Dimmer Light_EG_Wohnzimmer_Tisch "Dimmer Esszimmer Tisch [%d %%]" (EG_Wohnzimmer,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_EG_Wohnzimmer_Tisch", autoupdate="true" }
Dimmer Light_OG_Emelie_Decke_Dim "Dimmer Emelie [%d %%]" (OG_Emelie,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_OG_Emelie_Decke_Dim", autoupdate="true" }
Dimmer Light_OG_Jonathan_Decke_Dim "Dimmer Jonathan [%d %%]" (OG_Jonathan,AlleLichter) [ "Lighting" ] { channel="knx:device:bridge:generic:Light_OG_Jonathan_Decke_Dim", autoupdate="true" , homekit="Lighting, Lighting.Brightness" [dimmerMode="<mode>"]}
Rollershutter Shutter_EG_GaesteWc "Rolladen WC [%d %%]" (EG_GaesteWc, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_EG_GaesteWc", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(+10),Raise=(-10)", stateMappings="Closed=1:100,Open=0"]}
Rollershutter Shutter_EG_Kueche "Rolladen Küche[%d %%]" (EG_Kueche, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_EG_Kueche", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(+10),Raise=(-10)", stateMappings="Closed=1:100,Open=0"]}
Rollershutter Shutter_EG_Wohnzimmer_Fenster "Rolladen Wohnzimmer Fenster[%d %%]" (EG_Wohnzimmer, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_EG_Wohnzimmer_Fenster", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(+10),Raise=(-10)", stateMappings="Closed=1:100,Open=0"]}
Rollershutter Shutter_EG_Wohnzimmer_Terrasse "Rolladen Wohnzimmer Terrasse[%d %%]" (EG_Wohnzimmer, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_EG_Wohnzimmer_Terrasse", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(+10),Raise=(-10)", stateMappings="Closed=1:100,Open=0"]}
Rollershutter Shutter_OG_Schlafzimmer "Rolladen Schlafzimmer[%d %%]" (OG_Schlafzimmer, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_OG_Schlafzimmer", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(+10),Raise=(-10)", stateMappings="Closed=1:100,Open=0"]}
Rollershutter Shutter_OG_Bad "Rolladen Bad [%d %%]" (OG_Bad, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_OG_Bad", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(+10),Raise=(-10)", stateMappings="Closed=1:100,Open=0"]}
Rollershutter Shutter_OG_Emelie "Rolladen Emelie[%d %%]" (OG_Emelie, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_OG_Emelie", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(+10),Raise=(-10)", stateMappings="Closed=1:100,Open=0"]}
Rollershutter Shutter_OG_Jonathan "Rolladen Jonathan[%d %%]" (OG_Jonathan, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_OG_Jonathan", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(+10),Raise=(-10)", stateMappings="Closed=1:100,Open=0"], homekit="WindowCovering"}
Rollershutter Shutter_OG_Schlafzimmer_Dach "Dachfenster [%d %%]" (OG_Schlafzimmer, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_OG_Dachfenster_Schlafen", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(-10),Raise=(+10)", stateMappings="Closed=1:100,Open=0"]}
Rollershutter Shutter_OG_Dachfenster_Bad "Dachfenster Bad[%d %%]" (OG_Bad, Rollaeden) [ "Lighting" ] { channel="knx:device:bridge:generic:Shutter_OG_Dachfenster_Bad", autoupdate="true" , alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=0,Open=100,Lower=(-10),Raise=(+10)", stateMappings="Closed=1:100,Open=0"]}
Contact Door_EG_Eingangstuer "Eingangstür [MAP(de.map):%s]" <door> (EG_Flur, Doors) { channel="knx:device:bridge:generic:Door_EG_Eingangstuer", autoupdate="true" }
Contact Door_EG_WC "WC Tür [MAP(de.map):%s]" <door> (EG_GaesteWc, Doors) { channel="knx:device:bridge:generic:Door_EG_WC", autoupdate="true" }
Contact Door_EG_Terrassentuer "Terrassentür [MAP(en.map):%s]" <door> (EG_Wohnzimmer, Windows) { channel="knx:device:bridge:generic:Door_EG_Terrassentuer", autoupdate="true" }
Contact Door_OG_Badzimmertuer "Badezimmertür [MAP(de.map):%s]" <door> (OG_Bad, Doors) { channel="knx:device:bridge:generic:Door_OG_Badzimmertuer", autoupdate="true" }
Contact Door_OG_Badzimmertuer_Alexa "Badezimmertür Alexa[MAP(de.map):%s]" <door> { channel="knx:device:bridge:generic:Door_OG_Badzimmertuer_Alexa", autoupdate="true" }
Contact Window_EG_Kueche "Fenster Küche [MAP(en.map):%s]" (EG_Kueche, Windows) { channel="knx:device:bridge:generic:Window_EG_Kueche", autoupdate="true" }
Contact Window_EG_Wohnzimmer "Fenster Wohnzimmer [MAP(en.map):%s]" (EG_Wohnzimmer, Windows) { channel="knx:device:bridge:generic:Window_EG_Wohnzimmer", autoupdate="true" }
Contact Window_EG_GaesteWc "Fenster Gäste WC [MAP(en.map):%s]" (EG_GaesteWc, Windows) { channel="knx:device:bridge:generic:Window_EG_GaesteWc", autoupdate="true" }
Contact Window_OG_Bad "Fenster OG Bad [MAP(en.map):%s]" (OG_Bad, Windows) { channel="knx:device:bridge:generic:Window_OG_Bad", autoupdate="true" }
Contact Window_OG_Schlafzimmer "Fenster OG Schlafzimmer [MAP(en.map):%s]" (OG_Schlafzimmer, Windows) { channel="knx:device:bridge:generic:Window_OG_Schlafzimmer", autoupdate="true" }
Contact Window_OG_Emelie_Window "Fenster Emelie [MAP(en.map):%s]" (OG_Emelie, Windows) { channel="knx:device:bridge:generic:Window_OG_Emelie_Window", autoupdate="true" }
Contact Window_OG_Jonathan_Window "Fenster Jonathan [MAP(en.map):%s]" (OG_Jonathan, Windows) { channel="knx:device:bridge:generic:Window_OG_Jonathan_Window", autoupdate="true" , homekit="Switchable" }
Switch Window_OG_Schlafen_Dachfenster_KNX "Dachfenster Schlafen [MAP(en.map):%s]" (OG_Schlafzimmer) { channel="knx:device:bridge:generic:Window_OG_Schlafen_Dachfenster", autoupdate="true" }
Switch Window_OG_Bad_Dachfenster_KNX "Dachfenster Bad [MAP(en.map):%s]" (OG_Bad) { channel="knx:device:bridge:generic:Window_OG_Bad_Dachfenster", autoupdate="true" }
Contact Heating_KG "Heizung KG [MAP(hz.map):%s]" <heating> (KG, Heating) { channel="knx:device:bridge:generic:Heating_KG", autoupdate="true" }
Contact Heating_EG "Heizung EG [MAP(hz.map):%s]" <heating> (EG, Heating) { channel="knx:device:bridge:generic:Heating_EG", autoupdate="true" }
Contact Heating_OG_Bad "Heizung OG Bad [MAP(hz.map):%s]" <heating> (OG, Heating) { channel="knx:device:bridge:generic:Heating_OG_Bad", autoupdate="true" }
Contact Heating_OG_Emelie "Heizung OG Emelie [MAP(hz.map):%s]" <heating> (OG, Heating) { channel="knx:device:bridge:generic:Heating_OG_Emelie", autoupdate="true" }
Contact Heating_OG_Schlafen "Heizung OG Schlafen [MAP(hz.map):%s]" <heating> (OG, Heating) { channel="knx:device:bridge:generic:Heating_OG_Schlafen", autoupdate="true" }
Number Temperatur_EG_Wohnzimmer "Temperatur EG Wohnzimmer [%.1f °C]" <temperature> (Temperatur, EG_Flur) { channel="knx:device:bridge:generic:Temperatur_EG_Wohnzimmer", autoupdate="true" }
Contact Heating_OG_Jonathan "Heizung OG Jonathan[MAP(hz.map):%s]" <heating> (OG, Heating) { channel="knx:device:bridge:generic:Heating_OG_Jonathan", autoupdate="true" , homekit="Switchable" }
Number Temperatur_OG_Bad "Temperatur OG Bad [%.1f °C]" <temperature> (Temperatur,OG_Bad) { channel="knx:device:bridge:generic:Temperatur_OG_Bad", autoupdate="true" }
Number Temperatur_OG_Emelie "Temperatur OG Emelie [%.1f °C]" <temperature> (Temperatur,OG_Emelie) { channel="knx:device:bridge:generic:Temperatur_OG_Emelie", autoupdate="true" }
Number Temperatur_OG_Schlafen "Temperatur OG Schlafen [%.1f °C]" <temperature> (Temperatur,OG_Schlafzimmer) { channel="knx:device:bridge:generic:Temperatur_OG_Schlafen", autoupdate="true" }
Number Temperatur_OG_Jonathan "Temperatur OG Jonathan [%.1f °C]" <temperature> (Temperatur,OG_Jonathan) { channel="knx:device:bridge:generic:Temperatur_OG_Jonathan", autoupdate="true" }
Number Solltemp_KG "Solltemperatur KG [%.1f °C]" <temperature> (Temperatur, KG, KG_Buero) { channel="knx:device:bridge:generic:Solltemp_KG", autoupdate="true" }
Number Solltemp_EG "Solltemperatur EG [%.1f °C]" <temperature> (Temperatur, EG) { channel="knx:device:bridge:generic:Solltemp_EG", autoupdate="true" }
Number Solltemp_OG "Solltemperatur OG [%.1f °C]" <temperature> (Temperatur, OG) { channel="knx:device:bridge:generic:Solltemp_OG", autoupdate="true" }
Number Temperatur_OG_Schlafen_Soll "Solltemperatur Schlafen [%.1f °C]" <temperature> (OG_Schlafzimmer) { channel="knx:device:bridge:generic:Temperatur_OG_Schlafen_Soll", autoupdate="true" }
DateTime TimeKNX "Uhrzeit [%1$tH:%1$tM]" (Status) {channel="knx:device:bridge:generic:TimeKNX,ntp:ntp:local:dateTime", autoupdate="true" }
DateTime DatumKNX "Datum" (Status) {channel="knx:device:bridge:generic:Datum",channel="ntp:ntp:local:dateTime"}
DateTime Buszeit "Zeit und Tag" (Status) {channel="knx:device:bridge:generic:wochenzeit",channel="ntp:ntp:home:dateTime"}
Number Helligkeit_vorne "Helligkeit vorne [%.1f Lux]" (Wetterstation) { channel="knx:device:bridge:generic:Helligkeit_vorne", autoupdate="true" }
Number Helligkeit_rechts "Helligkeit rechts [%.1f Lux]" (Wetterstation) { channel="knx:device:bridge:generic:Helligkeit_rechts", autoupdate="true" }
Number Helligkeit_links "Helligkeit links [%.1f Lux]" (Wetterstation) { channel="knx:device:bridge:generic:Helligkeit_links", autoupdate="true" }
Number Maximale_Helligkeit "Maximale Helligkeit [%.1f Lux]" (Wetterstation) { channel="knx:device:bridge:generic:Maximale_Helligkeit", autoupdate="true" }
Number Aussentemperatur "Aussentemperatur Dach [%.1f °C]" (Temperatur,Wetterstation) { channel="knx:device:bridge:generic:Aussentemperatur", autoupdate="true" }
Number Windgeschwindigkeit "Windgeschwindigkeit [%.1f m/s]" (Wetterstation) { channel="knx:device:bridge:generic:Windgeschwindigkeit", autoupdate="true" }
Contact Regen_Sensor "Regen_Sensor Dach" (Wetterstation) { channel="knx:device:bridge:generic:Regen_Sensor", autoupdate="true" }
DateTime Lokale_Datum "DCF Datum" (Wetterstation) { channel="knx:device:bridge:generic:Lokale_Datum", autoupdate="true" }
DateTime Lokale_Zeit "DCF Zeit" (Wetterstation) { channel="knx:device:bridge:generic:Lokale_Zeit", autoupdate="true" }
Switch Zeit_anfragen "Zeit_anfragen" (Wetterstation) { channel="knx:device:bridge:generic:Zeit_anfragen", autoupdate="true" }
Switch Temperatursensor_Status "Temperatursensor Status" (Wetterstation) { channel="knx:device:bridge:generic:Temperatursensor_Status", autoupdate="true" }
Number Elevation "Elevation [%.1f Grad]" (Wetterstation) { channel="knx:device:bridge:generic:Elevation", autoupdate="true" }
Number Azimut "Azimut [%.1f Grad]" (Wetterstation) { channel="knx:device:bridge:generic:Azimut", autoupdate="true" }
Contact Wetterstation_C1_Schalten "Wetterstation C1 Schalten" (Wetterstation) { channel="knx:device:bridge:generic:Wetterstation_C1_Schalten", autoupdate="true" }
Number Wetterstation_C1_Schwellwert "Wetterstation C1 Schwellwert [%s Lux]" (Wetterstation) { channel="knx:device:bridge:generic:Wetterstation_C1_Schwellwert", autoupdate="true" }
