Thanks!
It still does not dim my spot…
I get this in my log, but the spots are not dimming, just turning off and on when i slide the switch in Basic UI:
2017-08-21 22:54:14.286 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 80
2017-08-21 22:54:15.297 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 75
2017-08-21 22:54:16.306 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 70
2017-08-21 22:54:17.321 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 65
2017-08-21 22:54:18.335 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 60
2017-08-21 22:54:19.350 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 55
2017-08-21 22:54:20.358 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 50
2017-08-21 22:54:21.367 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 45
2017-08-21 22:54:22.393 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 40
2017-08-21 22:54:23.407 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 35
2017-08-21 22:54:24.425 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 30
2017-08-21 22:54:25.432 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 25
2017-08-21 22:54:26.450 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 20
2017-08-21 22:54:27.451 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 15
2017-08-21 22:54:28.466 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 10
2017-08-21 22:54:29.475 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 5
2017-08-21 22:54:30.488 [ItemCommandEvent ] - Item ‘Loft_living_spot’ received command 0
