Hi.
I am starting up openHAB 2.5.10 to replace openHAB 1, and I got this problem with this DPT.
openHAB see this as a float, instead of 93 mA I got 0.93 mA.
DPT 7.xxx is a two byte unsigned value, in other word, 0…65535.
ETS says 93 mA.
Here is the output from the log:
2020-11-03 11:06:07.953 [vent.ItemStateChangedEvent] - energy_VK_Pumpe_A changed from 91.0 to 93.0
knx.things:
Type number : energy_VK_Pumpe_A “Energy” [ ga=“7.012:0/0/14” ]
knx.items:
Number energy_VK_Pumpe_A “Pumpe Strøm [%d mA]” { channel=“knx:device:bridge:termostat:energy_VK_Pumpe_A” }
I have tryed with %s and %.0f and it is the same.
sitemap:
Text item=energy_VK_Pumpe_A icon=energy
I am runding this on a Raspberry Pi 4, 4GB.
Is there an error in openHAB 2?
openHAB 1 has been rung for 4 years without any problem on Raspberry Pi 2 and PiDrive, and here it is correct.
Rune
