Hi
I have openHAB 2.2 up and running and all-in-all it is working quite well. I do have one problem and it’s a funny one! If I stop openHAB and try and dim my light everything dims nicely - I can go from about 10 % to 100% without any problems and by just keeping my finger on the switch. If I start openHAB I can only dim in 10% increments i.e. if I keep my finger on the switch it goes from e.g. 30% up to 40% perfectly (get brighter in 1 % increments) but then stops at 40%. I then need to take my finger off the dimmer and press dim again, it then goes from 40% to 50%. Very weird. Here is an example from the events.log file:
2018-01-21 17:17:48.678 [vent.ItemStateChangedEvent] - Dining_Dimmer changed from 30 to 40
2018-01-21 17:17:48.741 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command 40
2018-01-21 17:17:49.442 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command INCREASE
2018-01-21 17:17:50.138 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command INCREASE
2018-01-21 17:17:50.577 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command 50
2018-01-21 17:17:50.578 [vent.ItemStateChangedEvent] - Dining_Dimmer changed from 40 to 50
2018-01-21 17:17:51.335 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command INCREASE
2018-01-21 17:17:52.021 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command INCREASE
2018-01-21 17:17:52.457 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command 60
2018-01-21 17:17:52.458 [vent.ItemStateChangedEvent] - Dining_Dimmer changed from 50 to 60
2018-01-21 17:17:53.130 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command INCREASE
2018-01-21 17:17:53.860 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command INCREASE
2018-01-21 17:17:54.298 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command 70
2018-01-21 17:17:54.299 [vent.ItemStateChangedEvent] - Dining_Dimmer changed from 60 to 70
2018-01-21 17:17:54.362 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command 70
2018-01-21 17:17:54.770 [ome.event.ItemCommandEvent] - Item ‘Dining_Dimmer’ received command INCREASE
any ideas?
here is the relevant line in the items file:
Dimmer Dining_Dimmer “Dining Dimmer [%.1f]” (Dining, Lighting, myOpenHAB) [“Lighting”] {autoupdate=“true”, knx=“1/1/2+<1/3/2,1/2/2,<1/4/2”}
the services file just has the IPs added!
Too be perfectly clear - the switch works fine, I can turn the light on, off and can dim, only in 10% increments though?
Thank you for any help given
Ursus
