H guys,
my KNX binding was running very stable for almost two years. Since yesterday I’m receiving lost connections, and I have to disable/enable the gateway or restart the complete openhab service.
I don’t now what is the reason for that. I didn’t update the openhab version.
See the settings here:
It is a MDT IP Router, Secure is switched off. There should be enough open connections
This is coming from the logs:
2021-08-06 23:31:25.758 [ERROR] [net/IP Tunneling 192.168.100.10:3671] - close connection - maximum send attempts
tuwien.auto.calimero.KNXAckTimeoutException: maximum send attempts, no service acknowledgment received
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:250) [bundleFile:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:177) [bundleFile:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:264) [bundleFile:?]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:332) [bundleFile:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:243) [bundleFile:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:397) [bundleFile:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:354) [bundleFile:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.sendToKNX(AbstractKNXClient.java:459) [bundleFile:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.writeToKNX(AbstractKNXClient.java:419) [bundleFile:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.lambda$7(DeviceThingHandler.java:253) [bundleFile:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:148) [bundleFile:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:142) [bundleFile:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.handleCommand(DeviceThingHandler.java:248) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy2858.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemFollowProfile.onStateUpdateFromItem(SystemFollowProfile.java:60) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2021-08-06 23:31:25.760 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@15de5ed4': process communicator detached
java.lang.IllegalStateException: process communicator detached
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:396) ~[?:?]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.write(ProcessCommunicatorImpl.java:354) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.sendToKNX(AbstractKNXClient.java:459) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.writeToKNX(AbstractKNXClient.java:419) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.lambda$7(DeviceThingHandler.java:253) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:148) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:142) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.handleCommand(DeviceThingHandler.java:248) ~[?:?]
2021-08-06 23:31:25.763 [ERROR] [calimero.link.192.168.100.10:3671 ] - send error, closing link
tuwien.auto.calimero.knxnetip.KNXConnectionClosedException: send attempt on closed connection
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:215) ~[bundleFile:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:177) ~[bundleFile:?]
at com.sun.proxy.$Proxy2859.handleCommand(Unknown Source) [?:?]
2021-08-06 23:31:25.764 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@594ce437': process communicator detached
