Hello OpenHAB comunity,
About 1 month ago I bought a Raspberry Pi 4 with 4MB RAM and 32GB of SD memory, ans Raspbian OS and works perfectly.
Just I’m learning about openHAB and it’s great. I read a lot of information but I have a problem for configure the KNX/IP Gateway.
I tried put the system un Router and Tunnel mode, with NAT on and off, and others and nothing.!
I checked my IP Host, and comunication with knx device (JUNG IPS300SREG) with a ping and works well.
HOST: 192.168.0.30
KNX: 192.168.0.61
Here you have the configuration of KNX device
But always I have the same result… UNKNOWN
Some times put STATUS: OFFLINE - COMMUNICATION_ERROR
Here you have my openHAB version:
I don’t know if only configuring the THINGS in the BUILDING is enough, or I need to download any file into the raspberry (knx.thing).
Thank you for your help and suggestions.
Best regards.
