Does anyone have experience with this device and a possible connection?
I tried to use the default KNX/IP binding but that doesn’t seem to work at all.
I had a quick look and it seems that the Jigsaw only supports some proprietary protocol. Calimero (the library the KNX binding uses for bus connections) only supports IP routing/tunneling and serial connections.
Thanks for the reply Jan! Past days I was playing around a bit with both systems.
bOS has a RPC so by enabling that, I can address all devices via REST api.
Adding the code that I used here, if it can help someone in the future.
The only thing is that you will need some time to config all individual devices or have some proper programming skills.
url: "https://user:password@IP:443/API/RPC/SetValue/"
method: POST
verify_ssl: false
content_type: "application/json"
payload: '{"objectName":"Devices\\KNX\\Sturing verlichting\\Verlichting aan/uit\\Sturing L021 bureau aan/uit","valueName":"Value","Value":"true"}'
