I have problems with the communication from openhab2 over KNX-IP-Router to a knx group.
I get follow log messages:
2017-12-16 11:51:14.551 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items’
2017-12-16 11:51:19.013 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap’
2017-12-16 11:51:21.073 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.73:8080
2017-12-16 11:51:21.076 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.73:8443
2017-12-16 11:51:22.052 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-12-16 11:51:23.167 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-12-16 11:51:23.414 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-12-16 11:51:24.260 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 224.0.23.12:6720 in mode ROUTER.
2017-12-16 11:51:28.688 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber ‘org.eclipse.smarthome.core.thing.link.ThingLinkManager@1419179’ takes more than 5000ms.
2017-12-16 11:51:34.293 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item ‘knxItem’ from KNX bus: timeout waiting for group read response: timeout
2017-12-16 11:51:34.295 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address ‘2/1/2’ = '2’
2017-12-16 11:51:44.349 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item ‘knxItem’ from KNX bus: timeout waiting for group read response: timeout
2017-12-16 11:51:44.350 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address ‘2/1/2’ = '1’
2017-12-16 11:51:54.403 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item ‘knxItem’ from KNX bus: timeout waiting for group read response: timeout
2017-12-16 11:51:54.404 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address ‘2/1/2’ = '0’
2017-12-16 11:52:04.457 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item ‘knxItem’ from KNX bus: timeout waiting for group read response: timeout
2017-12-16 11:52:04.459 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Give up, could not read address ‘2/1/2’ after ‘3’ retries.
Is the warning from the EventManager a problem?
What can I do wrong, when I want read a group address?
Thank you in advance for your ideas.
