KNX - Rollershutter - What am I missing
The status is from Velux (the KLF200) but I want it posted to the KNX bus for a future visualization.
I don’t quite get the difference between Item-Control and just Item. As far as I understood, the current state is tracked somewhere. In one case (-control) it is in OpenHAB, in another case (without the -control part) it is handled directly in the KNX system.
Would it be correct to use a rollershutter-control and post updates on the status to the KNX bus? Because you mentioned that one shouldn’t use the <GA when it’s a -control item.
