Hello together
I have by a stupid backup error on my part now the chance to reinstall my entire knx <> openhab. so i now will use the OH3. I have now installed the openhab 3.0.0 on a docker (ubuntu server).
Unfortunately I can not get a connection to my KNX IP router. I tried several options. Here my config:
My Docker Compose File:
services:
openhab3:
image: "openhab/openhab:3.0.0"
container_name: openhab3
restart: unless-stopped
network_mode: "host"
volumes:
- "/etc/localtime:/etc/localtime:ro"
- "/etc/timezone:/etc/timezone:ro"
- "/var/docker/openhab3/addons:/openhab/addons"
- "/var/docker/openhab3/conf:/openhab/conf"
- "/var/docker/openhab3/userdata:/openhab/userdata"
environment:
OPENHAB_HTTP_PORT: "8080"
OPENHAB_HTTPS_PORT: "8443"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Berlin"
USER_ID: "1000"
GROUP_ID: "1000"
My openhab thing settings in the Code sektion:
UID: knx:ip:01c397e580
label: KNX/IP Gateway
thingTypeUID: knx:ip
configuration:
useNAT: true
readRetriesLimit: 3
ipAddress: 10.10.10.20
localIp: 10.10.10.196
autoReconnectPeriod: 60
type: ROUTER
localSourceAddr: 0.0.0
readingPause: 50
portNumber: 3671
responseTimeout: 10
The Log:
2021-02-03 23:15:15.058 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:01c397e580’ changed from UNKNOWN to OFFLINE
2021-02-03 23:15:15.061 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:01c397e580’ changed from OFFLINE to UNKNOWN
My tries:
- Change from router to tunnel mode
- set nat mode on/off
- Change networ mode in the compose file to host instead of port reservation
- serveral restarts
The Router is online and i can connect to it with the ETS and the Port 3671
I hope you have a few good ideas for me?
