I was looking around, I found some articles, but I’m not able to transfer it on my problem, sorry!
I recently activated some rules to control the shutters. But there are just some “UP” and “DOWN” command. But assumed I want to send a KNX Scene Group-Address which sets all shutters to a predefined % of closing? I’m lost!
How to send a command to a group-address?
I assume, I have to setup a swich or some other control in the *items file?! And send a related command in the *.rules file!?
You have to define one item for each group address you want to send to (exceptions are items which use more than one group address, e.g. rollershutter item uses three different group addresses) For recalling scenes I use this:
.items:
Number Scene_GF_Living_Shading "Beschattung" { knx="17.001:1/1/1" }
of course I got the scenes running. But after some try and error I’m still a bit confused about the scene no.
For a while a used the workaround sending scene-no n-1 to knx-bus.
…since I changed my rules, I mixed something up and my scenes doesn’t work well anymore…
Now I found your post on GitHub: Calimero Bug and I’m wondering if the problem still exists or what your solution has been?!
My KNX actors support scenes no. beginning from 1…
Yes, I got confused about this, too (long time ago…) The point is, knx Scene number “1” is on knx bus represented with a “0”, neither a bug in Calimero, nor in openHAB
Aha?
…in other words, does this mean, if my actors doesn’t support scene-no. “0”, I have to use openHab Scene-No. beginning with “2” and KNX will handle this like a “1”??
