Hello all,
I am trying to send DateTime to my KNX installation. I have followed some issue github to try to write things/items as it should. However I still see an error in the openhab log.
Can you help me?
2020-04-27 09:50:52.250 [DEBUG] [.internal.handler.DeviceThingHandler] - onGroupWrite Thing 'knx:device:EIBMarket001:knx_virtual' received a GroupValueWrite telegram from '1.1.3' for destination '7/4/0'
2020-04-27 09:50:52.253 [INFO ] [g.knx.internal.dpt.KNXCoreTypeMapper] - Translator couldn't parse data for datapoint type '19.001' (KNXFormatException).
2020-04-27 09:50:52.256 [INFO ] [g.knx.internal.dpt.KNXCoreTypeMapper] - Translator couldn't parse data for datapoint type '19.001' (KNXFormatException).
2020-04-27 09:50:52.258 [WARN ] [.internal.handler.DeviceThingHandler] - Ignoring KNX bus data: couldn't transform to any Type (destination='7/4/0', datapoint='command DP 7/4/0 'knx:device:EIBMarket001:knx_virtual', DPT id 19.001, low priority', data='0x78041B0932342400')
I have solved a bit my issue.
I have two openhab servers on the network (I am trying to make sure I can backup on to the other).
Thus it created this issue. When one server send the DateTime, the other one found a problem to decode it. That is why half of the messages are sent, and the other half is with issue.
I don’t know if it is a bug or only my non typical installation.
