I have a knx installation.
I have a group address (0/1/2) that is all lighting on the ground floor.
I added that to OH4 as a thing (switch), however I would only like to send an off-command.
how would I do that?
thanks
daniel
thanks
daniel
Just ensure only so send OFF
If the Item linked to the channel is named AllOff
in a rule only use AllOff.sendCommand(OFF)
(or similar in other rule languages)
in a sitemap use Switch item=AllOff mappings=[OFF="All Off!"]
in Main UI, use a Label Card or something similar:
component: oh-label-card
action: command
actionItem: AllOff
actionCommand: OFF
label: All Off!
slots: null
How about an inline script transformation between item and channel that, no matter what its input value is, always sends “OFF” to the channel? Then you would not depend on the UI.
