- Platform information:
- Hardware: Raspberry Pi 4
- openHAB version: 2.5.3.1
I’m new to Raspberry Pi and openHAB. I was able to set up openHAB on Rasperry Pi 4 and added KNX binding via Paper UI, KNX IP router and devices, like switch or shutter actuator. All things with physical address from ETS. Later, I’ve created channels for switch and roller shutter with appropriate group addresses from ETS.
The IP router and all devices shows the status online. But, on Page UI under Control, when I switch or click on UP or DOWN arrows for shutter, nothing happens. The log on openHAB 2 log viewer shows, the switch has been changed from OFF to ON or roller shutter from 0 to 100.
Do you have an idea, what should I check? Did I forget something?
Thank you very much!
Here my settings:
IP Router:
Network address: 224.0.23.12
Port: 3671
Local device address: 0.0.0
Local network address: my openHAB-IP
Connection type: Router
Switch actuator:
Address: 1.1.70 (PA from ETS)
Channel:
Address: 2/2/1 (GA from ETS to switch on the light). Channel is linked to the switch actuator
