OS: what OS is used and which version raspbian stretch
Java Runtime Environment: which java platform is used and what version : 1.8.0_11
openHAB version: 2.5.2
Issue of the topic:
With openhab 1, my knx temperature setup was working fine with this configuration:
items file :
/* Indoor Temperatures */
Number temp_hall_cible “Temperature [%.1f C]” { knx=“2/0/2+<9.001:2/0/3” }
Number temp_hall “Temperature [%.1f C]” { knx="+<9.001:2/0/0" }
sitemap file:
Setpoint item=temp_hall_cible label=“Temperature cible [%.1f C]” minValue=16 maxValue=24 step=0.5
Text item=temp_hall
I then migrated to openhab 2.5.2 using docker, but my temperature is not printed anymore in paper ui, here is my configuration :
knx.things
Type number : temp_hall_cible “Temperature” [ ga=“2/0/2+<9.001:2/0/3”]
Type number : temp_hall “Temperature” [ ga="+<9.001:2/0/0"]
knx.items
Number temp_hall “Temperature” { channel=“knx:device:bridge:generic:temp_hall” }
Number temp_hall_cible “Temperature” { channel=“knx:device:bridge:generic:temp_hall_cible” }
knx.sitemaps
Text item=temp_hall_cible
Text item=temp_hall
I just see “-” instead of my temperature value
