Hi there!
I am fairly new to openhab-coding. We build a house with knx and an external person did the programming in ETS and openhab (running still openHAB 3.4.4).
I wanted to add new KNX things, but it doesn’t work. All working things like thermostats, lights etc. are connected to a MDT-Router as a bridge in openHAB.
I tried to recreate the codes of the working things with the new knx thing. It always shows the error error:bridge (offline). What am I doing wrong?
Working code for the garage:
UID: knx:device:MDT-Router:knx_dummy_garage
label: KNX Dummy Garagentore
thingTypeUID: knx:device
configuration:
pingInterval: 9999999
readInterval: 120
fetch: false
bridgeUID: knx:ip:MDT-Router
channels:
- id: garagentor
channelTypeUID: knx:rollershutter
label: Garagentor
description: ""
configuration:
upDown: 4/2/0
stopMove: 4/2/1
position: 4/2/9+<4/2/9
Not working code for the gate:
UID: knx:device:MDT-Router:knx_dummy_hoftor
label: KNX Dummy Hoftor
configuration:
pingInterval: 600
readInterval: 0
fetch: false
channels:
- id: hoftor_impuls
channelTypeUID: knx:switch
label: Hoftor
description: null
configuration:
ga: 4/5/3
Long story short: We don’t have that external person available anymore, so I hope to find help here? Why can’t I add new KNX things? As long as I connect the new thing with the MDT-Router, it says error:bridge (offline).
