Timo98
(Timo )
May 6, 2021, 11:59am
1
Platform information: Win 10 VM client
OS: Win 10
Java Runtime Environment: 11
openHAB version: 3.0
Issue of the topic: simply can´t find the Folder or whatelse “knx.things” actually is.
I am a beginner to openHAB, i simply want to configure the knx bus.
I used this article to get started (ger only) Anbindung an den KNX-Bus - openHAB Dokumentation
rossko57
(Rossko57)
May 6, 2021, 12:06pm
2
You’re looking for xxxxx/conf/things folder, where xxx depends on your install. It already exists and contains a readme file,just browse for it.
Timo98
(Timo )
May 6, 2021, 12:09pm
3
found it but the folder only contains the readme file, do i have to create the “knx.things” or should be it installed by adding the Binding ?
thanks allready
rossko57
(Rossko57)
May 6, 2021, 12:12pm
4
Yes, it is entirely up to you to make a knx.things file.
Bear in mind you are probably following an outdated unofficial guide. You don’t have to make any kind of file, you can create Things and channels and Items in the GUI.
Might be useful in future, “file locations” -
