Hey there,
I’ve created a gateway between KNX and Zabbix: if a value is written to a certain GroupAddress on KNX, its GA and corresponding value are sent via a simple bash script and via zabbix_sender to a Zabbix monitoring system. Via Zabbix you can collect and visualize smart home data as well as create notifications if something is wrong.
Prerequisites:
- Installation of zabbix_sender
- OpenHAB KNX Add-on
A working configuration looks like this:
knx.things:
Type switch : basement_storageroom_presence "Basement storage room presence" [ ga="1/1/2" ]
knx.items:
Switch basement_storageroom_presence "Basement storage room presence [%s]" { channel="knx:device:bridge:generic:basement_storageroom_presence" }
knx.rules:
// Basement storage room presence
rule "basement_storageroom_presence"
Item basement_storageroom_presence changed
if(basement_storageroom_presence.state instanceof OnOffType) {
val basement_storageroom_presence_value = if (basement_storageroom_presence.state == ON) 1 else 0
executeCommandLine(Duration.ofSeconds(1), "/usr/local/bin/zabbix_send.sh", "1/1/2", basement_storageroom_presence_value.toString)
zabbix_send.sh:
#!/bin/bash
# /usr/local/bin/zabbix_send.sh
# Send a combination of GA and value to zabbix_sender.
# Configuration
# General options
# URL or ip address of your Zabbix server
zabbix_server="zabbix.example.com"
# Technical name of monitored host (as registered in Zabbix frontend)
registered_host="knx_gateway"
# Arguments in the order '[GA] [data]', e.g. '1/1/2 54'
# where '1/1/2' is the GA you want to send
# and '54' is the value you want to send (e.g. temperature)
group_address="$1"
data="$2"
# Preparations
# Make sure an option argument has been specified
if [ -z "$group_address" ]; then
echo "No 'GA' option specified. Please call this script as '$0 [GA] [data]', e.g. '$0 1/1/2 1'. Aborting."
exit 1
fi
if [ -z "$data" ]; then
echo "No 'data' option specified. Please call this script as '$0 [GA] [data]', e.g. '$0 1/1/2 1'. Aborting."
exit 1
fi
# Check if the zabbix_sender binary is present
if [ ! -x "/usr/bin/zabbix_sender" ]; then
echo "'zabbix_sender' binary not found or not executable, cannot continue. Aborting."
exit 1
fi
# Send to Zabbix
# Re-format this GA from 'x/x/x' to a canonified 'x_x_x',
# since Zabbix cannot parse slashes
group_address_canonified=$(echo $group_address | sed 's/\//_/g;' )
# Debug
#echo "/usr/bin/zabbix_sender -z $zabbix_server -s openhab -k $group_address_canonified -o $data"
# Send a key value pair to Zabbix
/usr/bin/zabbix_sender -z $zabbix_server -s $registered_host -k $group_address_canonified -o $data
# Feedback
if [ "$?" != "0" ]; then
echo "Sending message to Zabbix server failed. Aborting."
exit 1
fi
Comments, ideas and suggestions are welcome!
