Since Monday I have a problem.
After restarting my host server Windows Server 2016 and the openHAB 3.1 server, openHAB can no longer connect my GIRA IP interface.
The restart was necessary because of a Windows update. But nothing has changed with centOS and openHAB.
My openHAB ran on Hyper-V virtual centOS 8 for several months without any problems.
I only have one GIRA KNX IP interface.
The IP interface can connect 4 tunnels, but I use maximum three systems to connect to the bus. (ETS, Tobit David and openHAB).
If I enable the thing I get the following log:
16:46:01.695 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNXGateway’ changed from UNINITIALIZED (DISABLED) to INITIALIZING
16:46:01.722 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNXGateway’ changed from INITIALIZING to UNKNOWN
16:47:01.691 [DEBUG] [knx.internal.client.AbstractKNXClient] - Bridge knx:ip:KNXGateway is disconnecting from the KNX bus
16:47:01.693 [DEBUG] [knx.internal.client.AbstractKNXClient] - Bridge knx:ip:KNXGateway is connecting to the KNX bus
16:47:01.693 [DEBUG] [.binding.knx.internal.client.IPClient] - Establishing connection to KNX bus on 192.168.10.112:3671 in mode TUNNEL.
16:47:01.698 [ERROR] [Xnet/IP Tunneling 192.168.10.112:3671] - could not accept new connection (maximum reached)
16:47:01.699 [ERROR] [Xnet/IP Tunneling 192.168.10.112:3671] - establishing connection failed, error response from control endpoint /192.168.10.112:3671: could not accept new connection (maximum reached)
16:47:01.700 [DEBUG] [knx.internal.client.AbstractKNXClient] - Error connecting to the bus: error response from control endpoint /192.168.10.112:3671: could not accept new connection (maximum reached)
tuwien.auto.calimero.KNXRemoteException: error response from control endpoint /192.168.10.112:3671: could not accept new connection (maximum reached)
at tuwien.auto.calimero.knxnetip.ClientConnection.connect(ClientConnection.java:201) ~[?:?]*
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.<init>(KNXnetIPTunnel.java:158) ~[?:?]*
at org.openhab.binding.knx.internal.client.IPClient.getConnection(IPClient.java:110) ~[?:?]*
at org.openhab.binding.knx.internal.client.IPClient.createKNXNetworkLinkIP(IPClient.java:93) ~[?:?]*
at org.openhab.binding.knx.internal.client.IPClient.establishConnection(IPClient.java:80) ~[?:?]*
at org.openhab.binding.knx.internal.client.AbstractKNXClient.connect(AbstractKNXClient.java:178) ~[?:?]*
at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?]*
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]*
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]*
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]*
at java.lang.Thread.run(Thread.java:829) [?:?]*
16:47:01.703 [DEBUG] [knx.internal.client.AbstractKNXClient] - Bridge knx:ip:KNXGateway is disconnecting from the KNX bus
16:47:01.706 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘knx:ip:KNXGateway’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): error response from control endpoint /192.168.10.112:3671: could not accept new connection (maximum reached)
My thin is configuratet as follow:
label: KNX/IP Gateway
thingTypeUID: knx:ip
configuration:
useNAT: false
readRetriesLimit: 3
ipAddress: 192.168.10.112
autoReconnectPeriod: 60
localIp: 192.168.10.113
type: TUNNEL
localSourceAddr: 0.0.0
readingPause: 50
portNumber: 3671
responseTimeout: 10
localIp is the IP adress of the openHAB server
In the KNX project, the localSourceAddr is actually 1.1.1 but I tried this too
I tried the following:
- switch the IP interface off and on again
- reprogram the IP interface
- Changed the switch port and switched it off and on
- restart all server
- binding and thing deleted and reinstalled
- booted old clean saved image
- try router mode
- closed all other software (tunnels)
- searched the whole internet
But openHAB still cannot connect. My ETS can almost always connect. Only sometimes I get the message that no more tunnels are available.
But when I stop ETS there must be a free tunnel.
How can I see more than in the log? Can I display the existing connections? What else can I try.
A new IP interface cannot be the solution, it works perfectly with ETS and Tobit David.
Thank you for ideas and hlep…
