Hello guys,
I finally made the decsision to migrate to knx2.
I was not able to find a conclusive answer if there is an easy way to generate the things file automatically from ETS. I am using ETS4 atm and consider updateing to ETS5 if this brings a comepetitative advantage,
Why automatically. I am maintaining two seperate installations and I want to avoid to create two different representations fo the knx setup in ETS and in OH for each of the installations
Is there an easy way?
I understood there is a lively discussion about integrating such a feature in the knx2 binding. That would be perfect, understood. But simpler solutions like a python script which transferes the content of the knxproj file into a knx.thing file would be alread a good start.
Is there anything available?
Regards
Ralf
