Hello
I am also about to migrate from knx1 to 2 and I have to admit : it is a pain. I was delaying it until now the OH3 migration requires it.
I use a clean setup (Docker) and I gradually want to migrate my items - until I can make the big switch.
If I use the UI - it works fine, so the setup in general works. But creating the files does have it’s pitfalls:
I have tried Jo’s script - but I was not lucky. The resulting Thing file - only contained a generic device with a few channels.
So back to basics and try it manually. With ~70 devices it should be manageable - but I also fail here:
This is my things file:
Bridge knx:ip:bridge "ABB Gateway" [
ipAddress="192.168.0.119",
useNAT=true,
portNumber=3671,
type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=31,
localSourceAddr="0.0.0"
Thing device ABB16Fach "ABB 16Fach Schaltaktor"[
// device ID: M-0002_H-2CDG.20110.20103.20R0011-1_P-2CDG.20110.20103.20R0011
address="1.1.101",
fetch=false,
pingInterval=600,
readInterval=0
Type switch: Licht_Buero "Buero" [ga="1/2/4"]
When I upload the thing file I get the following error in the log:
2021-01-11 17:11:20.163 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'knx.things', using it anyway: Provide a thing UID in this format: <bindingId>:<thingTypeId>:<thingId> 2021-01-11 17:11:20.190 [WARN ] [.thing.internal.GenericThingProvider] - Thing device does not have a bridge so it needs to be defined in full notation like <bindingId>:device:ABB16Fach
And the Thing does not appear.
