I am in the process of migrating to KNX2. I got almost everything working as expected - except one special function.
I receive brightness values from my weather station and I use them to send it to the KNX bus in order to control the rollershutters accordingly.
I use a 10 minute floating average in order to not move them to often.
My problem is now that sending the value to the bus triggers an endless loop of updating states and knx telegrams when using the configuration below
knx.things
Type number-control : solarRadiation [ga="0/2/9"]
knx.items
Number SolarRadiationAverage "Helligkeit [%.0f lux]" (KNX) {channel="knx:device:knxbridge:rollershutterControl:solarRadiation"}
knx.rules
rule "Send an average value for brightness every time a new value is incoming"
Item WS_SolarRadiation received update
sendCommand(SolarRadiationAverage, WS_SolarRadiation.averageSince(now.minusMinutes(10)) as Number)
When researching the cause of this error I stumbled over the following Github Issue. The recommendation there is to add autoupdate=“false” to the item config.
When doing this, the value ist not send at all.
Can anyone give me an advice on how to fix this error?
