I am using the new KNX2 binding and have a strange issue. After some time working the KNX2 binding disconnects from the bus, usually during the first 10-48 hours.
I tested a local KNX interface as well as an MDT IP gateway - same behaviour.
The following error message is logged:
2018-06-20 14:31:48.558 [WARN ] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - connection state response: server could not find active data connect
ion with specified ID (channel 1)
2018-06-20 14:31:58.548 [WARN ] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - connection state response: server could not find active data connect
2018-06-20 14:32:08.545 [WARN ] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - connection state response: server could not find active data connect
2018-06-20 14:32:18.548 [WARN ] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - connection state response: server could not find active data connect
2018-06-20 14:32:28.634 [WARN ] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - received disconnect response status 0x21 (no active data connection
with that ID)
2018-06-20 14:32:28.666 [WARN ] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - close connection - no heartbeat response
2018-06-20 14:32:28.810 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:bridge is disconnecting from the KNX bus
2018-06-20 14:32:28.911 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:bridge is connecting to the KNX bus
2018-06-20 14:32:28.917 [DEBUG] [binding.knx.internal.client.IPClient] - Establishing connection to KNX bus on localhost:3671 in mode TUNNEL.
2018-06-20 14:32:28.930 [ERROR] [p.KNXnet/IP Tunneling 127.0.0.1:3671] - establishing connection failed, null
2018-06-20 14:32:28.945 [DEBUG] [nx.internal.client.AbstractKNXClient] - Error connecting to the bus: null
java.lang.InterruptedException: null
at java.lang.Object.wait(Native Method) ~[?:?]
at tuwien.auto.calimero.knxnetip.ConnectionBase.waitForStateChange(ConnectionBase.java:541) ~[?:?]
at tuwien.auto.calimero.knxnetip.ClientConnection.connect(ClientConnection.java:190) ~[?:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.<init>(KNXnetIPTunnel.java:159) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.getConnection(IPClient.java:107) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.createKNXNetworkLinkIP(IPClient.java:90) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.establishConnection(IPClient.java:77) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.connect(AbstractKNXClient.java:178) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.connectIfNotAutomatic(AbstractKNXClient.java:164) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.readNextQueuedDatapoint(AbstractKNXClient.java:272) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.lambda$1(AbstractKNXClient.java:199) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
2018-06-20 14:32:29.123 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:bridge is disconnecting from the KNX bus
i tried routing but it didn’t work, came across the “use TUNNEL if routing does not work” recommendation.
I am using a local KNX TUPUART Interface in that case, connections works. Host is a beaglebone.
I have the same problem when i use the remote IP of the external IP Interface.
openhab tries to connect to the multicast port - connection times out.
What am i doing wrong?
Tried “localip: 192.168.188.10” as well - no success.
KNXD uses 6720 per default. Strange thing.
I switched back to using the IP Interface from MDT. Although i have a similar problem there since i switched to the knx2 binding of OH. It also stops working but with a different error.
Worked with the knx1 binding before without problems
Will update here with the new error.
Similar problem when using the Remote MDT interface.
2018-06-27 22:04:43.675 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:bridge is disconnecting from the KNX bus
2018-06-27 22:04:43.688 [DEBUG] [nx.internal.client.AbstractKNXClient] - The KNX network link was detached from the process communicator
2018-06-27 22:04:43.706 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:bridge is connecting to the KNX bus
2018-06-27 22:04:43.715 [DEBUG] [binding.knx.internal.client.IPClient] - Establishing connection to KNX bus on 192.168.188.29:3671 in mode TUNNEL.
2018-06-27 22:04:43.746 [ERROR] [net/IP Tunneling 192.168.188.29:3671] - establishing connection failed, null
2018-06-27 22:04:43.760 [DEBUG] [nx.internal.client.AbstractKNXClient] - Error connecting to the bus: null
2018-06-27 22:04:43.991 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:bridge is disconnecting from the KNX bus
Stopping and restarting the KNX bundle solves the problem. For some hours at least.
The old knx1 binding worked with this hardware and gateway setup without problems.
I don’t know what could be wrong…configs look good
It could be a bug with the binding, it could be a comms issue…
Double check networking stuff between the OH2 host and the MDT interface (swap UTP cables, Ports on the Switch, ethernet card on the host, go direct for testing if possible). What hardware are you running OH2 on? (rPi or something else?).
Can you test the KNX2 binding connectivity on another host running OH2 ?
Try to enable TRACE on the tuwien.auto.calimero also to see if anything interesting comes up.
Hardware is the same as with OH2 and knx1 (beaglebone connected to GBIT Switch).
With knx1 it just worked.
2018-06-29 21:02:29.078 [DEBUG] [nx.internal.client.AbstractKNXClient] - The KNX network link was detached from the process communicator
2018-06-29 21:02:29.081 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:MDT is disconnecting from the KNX bus
2018-06-29 21:02:29.095 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:MDT is connecting to the KNX bus
2018-06-29 21:02:29.292 [DEBUG] [binding.knx.internal.client.IPClient] - Establishing connection to KNX bus on 192.168.188.29:3671 in mode TU
NNEL.
2018-06-29 21:02:29.085 [DEBUG] [.knx.handler.AbstractKNXThingHandler] - An error occurred while testing the reachability of a thing 'knx:dev
ice:MDT:ug_sa1'
tuwien.auto.calimero.link.KNXLinkClosedException: link closed
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:348) ~[?:?]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:222) ~[?:?]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.sendData(TransportLayerImpl.java:372) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.send(ManagementClientImpl.java:797) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.sendWait2(ManagementClientImpl.java:824) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.readDeviceDesc(ManagementClientImpl.java:447) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementProceduresImpl.isAddressOccupied(ManagementProceduresImpl.java:310) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.isReachable(AbstractKNXClient.java:338) ~[?:?]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.pollDeviceStatus(AbstractKNXThingHandler.java:144) ~[?:?]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.lambda$1(AbstractKNXThingHandler.java:184) ~[?:?]
2018-06-29 21:02:29.334 [ERROR] [net/IP Tunneling 192.168.188.29:3671] - establishing connection failed, null
2018-06-29 21:02:29.345 [DEBUG] [nx.internal.client.AbstractKNXClient] - Error connecting to the bus: null
2018-06-29 21:02:29.579 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:MDT is disconnecting from the KNX bus
enabled debug - not really helpful - right?
considering to migrate back to KNX1 binding now
Completely purged my openhab2 installation, wiped all configs, etc.
reinstalled a fresh 2.3 - now everything seems to be fine with using the knx2 binding
No KNX disconnect any more for 4 days now.
Jep, everything still working. I completely wiped everything, in my old installation i had some config files from knx1 binding left - thought that would be no problem cause the binding was inactive.
Thanks, also reinstalled openhab and it seems to work fine. No problems for 24h, never had that since using the knx2 binding.
Would be really interesting what causes the problem. I uninstalled the old knx binding, cleared the cache,… but it didn’t help. Uninstall and a fresh openhab2 install and it seems to work fine.
Wanted to add some information. The clean openh2 installation worked fine, so no more disconnects from knx.
However, after about 3 weeks I found out that querying of my Kostal Pico inverter does not work anymore because I forgot to reinstall the HTTP binding. After reinstalling it it seems the problem reoccurred. The next day openhab disconnected again. I removed the HTTP binding and everything works fine.
I have to do another check, might have been a coincidence, but maybe there is some side effect between those bindings…
I have several fresh OH 2.3 installations and have the same problem. For some of them problem appeared after few months of work and for others after few days.
For now I have workaround - rule that restarts bundle when knx ip bridge thing changed status to UNINITIALIZED. Since KNX binding is the most important to me I’m interested in the final solution.
Are you using file thing configuration or PaperUI?
Import the public key (sudo -u openhab cat openhab.id_rsa.pub) into /var/lib/openhab2/etc/keys.properties like
openhab=AAAAB3NzaC1kc3M…XWKpeyW789IBpcZfyYQ=,g:admingroup
Be aware that the leading “ssh-key” and trailing “user@server” has to be omitted.
