KNXbinding is not present
Hi im totally new with openhab
but working with knxsystem .
now i wondering what to do with the bindings ,it does`nt seem to work for me
ive tried to set config to router and tunnel
When i start the openhab it writes[KNXbinding configurations is not present]
what does that mean ?
openHAB1 or openHAB2?
Hi Udo thanks for being so fast.
I downloaded Openhab runtime for windows from your download page.
Do you mean http://www.openhab.org/getting-started/downloads.html?
There is no download for windows except the openHAB Designer, as openHAB is written in Java it is almost OS-independly :slight_smile:
So did you setup the knx binding in openhab.cfg?
What about the configuration (only knx part)?
Yes i did the config in openhab.cfg
And only did the knx part.
So please show us your knx configuration from openhab.cfg :slight_smile:
And maybe you set the logging level for the KNX binding to DEBUG and provide that part of the log also here.
I dont know were to set the logging level?
This is my file what is wrong?
Hm. Don’t see a file…
For the logging level see here: https://github.com/openhab/openhab/wiki/KNX-Binding
Scroll to the very end, it’s just one line in a config file.
Cant you see this file
Sorry I don’t see a file. Maybe u just copy&paste the content here in?
HI i dont seem to get this to work ,is it some other configurations that i must do.
when i start openhab it says that knx binding is not present.
THANKS, JÖRGEN
KNX gateway IP address
(optional, if serialPort or connection type ‘ROUTER’ is specified)
#knx:ip=192.168.1.52
Local KNX Binding bus address.
Use it, when two or more openHAB Instances are connected to the same KNX bus.
(optional, defaults to 0.0.0)
#knx:busaddr=1.1.255
Ignore local KNX Events, prevents internal events coming from
‘openHAB event bus’ a second time to be sent back to the ‘openHAB event bus’.
Note: To send back events second time is a Bug, but for backward compatibility, the behavior is not changed.
For new installations, its recommend to set “knx:ignorelocalevents=true”
(optional, defaults to false)
#knx:ignorelocalevents=false
KNX IP connection type. Could be either TUNNEL or ROUTER (optional, defaults to TUNNEL)
Note: If you cannot get the ROUTER mode working (even if it claims it is connected),
use TUNNEL mode instead with setting both the ip of the KNX gateway and the localIp.
#knx:type=router
KNX gateway port (optional, defaults to 3671)
Note: If you use eibd, setting to 6720
#knx:port=
Local endpoint to specify the multicast interface, no port is used (optional)
#knx:localIp=192.168.1.157
Serial port of FT1.2 KNX interface (ignored, if ip is specified)
Valid values are e.g. COM1 for Windows and /dev/ttyS0 or /dev/ttyUSB0 for Linux
#knx:serialPort=
Pause in milliseconds between two read requests on the KNX bus during
initialization (optional, defaults to 50)
#knx:pause=50
Timeout in milliseconds to wait for a response from the KNX bus (optional,
defaults to 10000)
#knx:timeout=10000
Number of read retries while initialization items from the KNX bus (optional,
defaults to 3)
#knx:readRetries=9
Seconds between connect retries when KNX link has been lost
0 means never retry, it will only reconnect on next write or read request
Note: without periodic retries all events will be lost up to the next read/write
request
(optional, default is 0)
#knx:autoReconnectPeriod=10
Auto refresh feature
Number of entries permissible in the item refresher queue.
(optional, defaults to 10000)
#knx:maxRefreshQueueEntries=100
Number of parallel threads for refreshing items. (optional, defaults to 5)
#knx:numberOfThreads=5
Seconds to wait for an orderly shutdown of the auto refresher’s
ScheduledExecutorService. (optional, defaults to 5)
#knx:scheduledExecutorServiceShutdownTimeoutString=5
Did you copy the knx addon to the addons folder?
For code pasting, please use backticks ` around the code to prevent malforming (e.g. the # will end up in Headline style)
#headline
versus
#headline
:slight_smile:
