Hi folks,
I still have an open thread on that matter but it’s quite a while ago I’ve started this. In the meantime, I’ve updated to the most recent openhabian and even got the KNXD running with the Weinzierl Module (BAOS 838). Unfortunately only once, then knxd quits with this message within the journal:
Sep 11 09:05:20 openhabian knxd[2514]: E00000044: [32:C.ft12cemi] reset timed out
Sep 11 09:05:20 openhabian knxd[2514]: F00000105: [27:C.ft12cemi] Link down, terminating
Sep 11 09:05:20 openhabian systemd[1]: knxd.service: Main process exited, code=exited, status=1/FAILURE
Any ideas - I haven’t the slightest one and even don’t know where to start.
Besides, I installed the brigde while obeying all the comments around, it’s Online (even though KNXD quit in the meantime).
UID: knx:serial:8819d0fefc
label: KNX FT1.2 Interface
thingTypeUID: knx:serial
configuration:
useCemi: false
autoReconnectPeriod: 60
serialPort: /dev/ttyAMA0
readingPause: 50
readRetriesLimit: 3
responseTimeout: 10
Installed a generic device - Online.
Installed a channel for a simple switch - no problems.
UID: knx:device:8819d0fefc:9cf952e415
label: KNX Device
thingTypeUID: knx:device
configuration:
pingInterval: 0
readInterval: 0
fetch: false
bridgeUID: knx:serial:8819d0fefc
channels:
- id: L_A1L_BIRD_EIN_AUS
channelTypeUID: knx:switch-control
label: L_A1L_BIRD_EIN_AUS
description: “”
configuration:
ga: 1/0/5+<1/6/5
Linked an item, created a page, added a card.
label: Overview
blocks:
- component: oh-block
config: {}
slots:
default:
- component: oh-grid-row
config: {}
slots:
default:
- component: oh-grid-col
config: {}
slots:
default:
- component: oh-toggle-card
item: L_A1L_BIRD_EIN_AUS
masonry: null
grid: null
canvas: null
Does it switch something - nope!
The ETS bus monitor is silent like the relaxing room in a spa.
Actually, I’m running out of time.
This is supposed to be ligthing control installation for a birds refugee. Although I did most of the logic on the KNX side, the OpenHAB/HabPanel installation is considered to be the control/monitoring station. I’m in the opinion, this is what OpenHAB is for… what else, if not?
Please help me - I have no problem to throw some money or other compensation in here.
I’m very much ok with the statement, that my combination (KNX, KNXD/Weinzierl) is not going to work stable - then I simply save the time and thankfully accept any alternative you may suggest. I do all this on my spare time and I donate the hardware to the refugee. This is why I’m unable to spend endless hours.
Christian.
