Reference is the Kodi Binding doc here:
In the refrence there is a channel called “shownotification” listed, but I don’t see this channel in the Paper UI.
Is this channel not supported anymore or do I miss something?
Hi Christian,
Did you check the advanced
section hidden behind the “Show more” button?
Just now but there is only the webinterface Port and the Port is correct.
Webinterface works.
Please correct me if I am wrong but I guess you used the wrong button - the Edit button. Directly above the list not channels you can see on the right hand side a “Show more” button:
Thank you very much. Now the channels are showing.
