I have a raspberry pi 3 with openhab 2 setup and running with no problems. I installed openhab 2 from this tutorial.
Now I want to install kodi and use the raspberry simultaneously as my home automation server and a media player.
Which tutorial should I use to install kodi properly? I had read in this forum that some people have problems with the ports that openhab uses during start up.
Thank you
I would not recommend installing both on one Pi.
I have not tried it, but I would guess the system has not enough memory for both.
And once openhab has not enough memory it starts to swap out the rules and it take a couple of seconds to ececute rules and commands.
At least that is what I experianced when I had another âbigâ application running beside openhab.
But installing Kodi on raspbian is very easy nowerdays.
http://kodi.wiki/view/HOW-TO:Install_Kodi_on_Raspberry_Pi#Raspbian
Thank you very much for your answer Christoph
I use both (even plus hyperion to drive led backlight) on one machine (RPi3) without bigger issues. However it caused quite high CPU temperature (about 70°C during summer) on idle and sometimes full HD videos are dropping few frames during playback (reboot helps if the issue persists).
Besides that everything works fine but I donât use many rules and my setup is quite simple (about 20 items more or less).
Iâve installed OSMC via installer and then openhab, influx, grafana using apt.
Thank you Pawel
I am facing a problem to run Kodi along with openHAB. I run openHAB 2.1.0 in a quite fresh and clean installation. after updating, upgrading and installing Kodi via command line I try to run it from there. but instead I get an error message: "* failed to add service - already in use? segmentation fault (core dumped) crash report available at home /openhabian/kodi_crashlogâŠ
I have done some research on google, installed mesa-utils for example. done reboots each time, but still get this crash. I am happy to provide the log, if wanted. it might be of interest that my graphics are on-board Intel 520. any help is appreciated!
I have put the crashlog to pastebin - please see here: http://paste.debian.net/999616/
is there anybody that has had the same challenge or a solution?
ok, it is solved - got Kodi running in parallel to openHAB. had to change raspi-config âAdvanced Settingsâ with
- give the GPU 256MB RAM and
- select the legacy display driver
