Hello!
I set the kodi to pause. And then I turn on the playback. And in the logs I see this:
2017-04-07 11:01:43.285 [ItemStateChangedEvent ] - myKodi_control changed from PAUSE to PLAY
2017-04-07 11:01:43.279 [ERROR] [i.internal.protocol.KodiClientSocket] - Error handling event {"jsonrpc":"2.0","method":"Player.OnPlay","params":{"data":{"item":{"id":29,"type":"movie"},"player":{"playerid":-1,"speed":1}},"sender":"xbmc"}} player state change message: null
java.lang.NullPointerException
at org.openhab.binding.kodi.internal.protocol.KodiConnection.requestPlayerUpdate(KodiConnection.java:237)[184:org.openhab.binding.kodi:2.0.0]
at org.openhab.binding.kodi.internal.protocol.KodiConnection.processPlayerStateChanged(KodiConnection.java:370)[184:org.openhab.binding.kodi:2.0.0]
at org.openhab.binding.kodi.internal.protocol.KodiConnection.handleEvent(KodiConnection.java:342)[184:org.openhab.binding.kodi:2.0.0]
at org.openhab.binding.kodi.internal.protocol.KodiClientSocket$KodiWebSocketListener$2.run(KodiClientSocket.java:157)[184:org.openhab.binding.kodi:2.0.0]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_121]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
What am I doing wrong?
