thank you for that - i am having problems with labels in general. They have the same height as the other boxes with switches etc.
Can you please explain on how i can make those label boxes thinner? Ideally only the half size so being thinner than all other elements…
thnx for the widget i use it to define my rooms light switches and its so cool.I have a request though,can you add or modify it so it can be used also as a switch?
I added to the first post the last version of my widget.
Ist now supporting URL/Dashboard links and letter spacing.
In addition you can use it as “Dashboard Label” (experimental feature - customer widget).
