I added a new lambda function and tried again with the same results so I don’t think it’s related to the ‘1’ value in the parameter.
val lambda2 = [ GenericItem sensorX, GenericItem switchX |
logInfo( logName, sensorX.name + " state is " + sensorX.state )
logInfo( logName, switchX.name + " state is " + switchX.state )
true
rule "test sensor 1"
Item test_sensor1 changed
logInfo( logName, "starting: 'test sensor 1' rule...")
//lambda1.apply( test_sensor1, test_switch1, 1 )
lambda2.apply( test_sensor1, test_switch1 )
logInfo( logName, "ending: 'test sensor 1' rule!")
openhab.log
2020-02-01 16:53:30.626 [INFO ] [eclipse.smarthome.model.script.DEBUG] - test_sensor1 changed from: OFF to: ON
2020-02-01 16:53:30.627 [INFO ] [eclipse.smarthome.model.script.test1] - starting: 'test sensor 1' rule...
2020-02-01 16:53:30.629 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'test sensor 1': null
