Hello all,
I’m having this rule works fine sometimes and sometimes logs errors, complaining about a global variable
ide error msg:
Cannot refer to the non-final variable RunFor inside a lambda expression(org.eclipse.xtext.xbase.validation.IssueCodes.invalid_mutable_variable_access)
the variables inside the createTimer closure is the highlighted for errors by vscode ide and Sometimes I’m getting errors in log view and sometimes everything works fine. any way it is still unclean code. and I hate it, especially it is repeated for 5 switches !
var Timer myTimer01 = null
var String myCommand01 = "ON"
rule "Timer01 Switch"
Item Timer01 changed
if(myTimer01 !== null){
myTimer01.cancel()
myTimer01 = null
if(myTimer01 === null){
var Number RunFor = (Timer01RunFor.state as Number).intValue()
if(RunFor <= 0) RunFor = 5
var Number StopFor = (Timer01StopFor.state as Number).intValue()
if(StopFor <= 0) StopFor = 5
myTimer01 = createTimer(now, [ |
if (Timer01.state == ON) {
if (myCommand01 == "ON") {
Timer01Group.members.forEach[ i | i.sendCommand(ON) ]
myCommand01 = "OFF"
myTimer01.reschedule(now.plusMinutes(RunFor))
} else if (myCommand01 == "OFF") {
Timer01Group.members.forEach[ i | i.sendCommand(OFF) ]
myCommand01 = "ON"
myTimer01.reschedule(now.plusMinutes(StopFor))
} else {
myCommand01 = "ON"
myTimer01.cancel()
myTimer01 = null
}else{
logInfo("Timer01", "myTimer01 !== null")
Thanks .
