lastUpdate someway drifting (OH 3.01)
I have written a small rule to test the “lastUpdate” function
rule "lastTest"
    Time cron "0 0/2 9-16 ? 4-10 * *"
    gEast.members.forEach [item |
    logInfo("shader", "--")
    logInfo("shader", "item {}", item )
    logInfo("shader", "last update  {}", item.lastUpdate())
    logInfo("shader", "difference {}", now.toInstant.toEpochMilli - item.lastUpdate.toInstant.toEpochMilli)
and this is what the log looks like
2021-06-01 12:58:00.165 [INFO ] [org.openhab.core.model.script.shader] - --
2021-06-01 12:58:00.179 [INFO ] [org.openhab.core.model.script.shader] - item Bathroom_Shutter (Type=RollershutterItem, State=69, Label=Rollade Badezimmer, Category=null, Groups=[gBathRoom, gShutter, gUpperFloor, gEast])
2021-06-01 12:58:00.186 [INFO ] [org.openhab.core.model.script.shader] - last update  2021-06-01T12:57+02:00[Europe/Berlin]
2021-06-01 12:58:00.195 [INFO ] [org.openhab.core.model.script.shader] - difference 60191
2021-06-01 12:58:00.199 [INFO ] [org.openhab.core.model.script.shader] - --
2021-06-01 12:58:00.203 [INFO ] [org.openhab.core.model.script.shader] - item LeonEast_Shutter (Type=RollershutterItem, State=67, Label=Rollade Leon Osten, Category=null, Groups=[gLeon, gShutter, gUpperFloor, gEast])
2021-06-01 12:58:00.209 [INFO ] [org.openhab.core.model.script.shader] - last update  2021-06-01T12:57+02:00[Europe/Berlin]
2021-06-01 12:58:00.217 [INFO ] [org.openhab.core.model.script.shader] - difference 60213
2021-06-01 12:58:00.224 [INFO ] [org.openhab.core.model.script.shader] - --
2021-06-01 12:58:00.232 [INFO ] [org.openhab.core.model.script.shader] - item Bedroom_Shutter (Type=RollershutterItem, State=69, Label=Rollade Schlafzimmer, Category=null, Groups=[gBedRoom, gShutter, gUpperFloor, gEast])
2021-06-01 12:58:00.241 [INFO ] [org.openhab.core.model.script.shader] - last update  2021-06-01T12:57+02:00[Europe/Berlin]
2021-06-01 12:58:00.249 [INFO ] [org.openhab.core.model.script.shader] - difference 60245
2021-06-01 13:00:00.163 [INFO ] [org.openhab.core.model.script.shader] - current temperature localCurrentTemperature (Type=NumberItem, State=23.97 °C, Label=Aktuelle Temperatur, Category=temperature)
2021-06-01 13:00:00.165 [INFO ] [org.openhab.core.model.script.shader] - --
2021-06-01 13:00:00.179 [INFO ] [org.openhab.core.model.script.shader] - item Bathroom_Shutter (Type=RollershutterItem, State=69, Label=Rollade Badezimmer, Category=null, Groups=[gBathRoom, gShutter, gUpperFloor, gEast])
2021-06-01 13:00:00.185 [INFO ] [org.openhab.core.model.script.shader] - last update  2021-06-01T12:59+02:00[Europe/Berlin]
2021-06-01 13:00:00.192 [INFO ] [org.openhab.core.model.script.shader] - difference 60188
2021-06-01 13:00:00.195 [INFO ] [org.openhab.core.model.script.shader] - --
2021-06-01 13:00:00.199 [INFO ] [org.openhab.core.model.script.shader] - item LeonEast_Shutter (Type=RollershutterItem, State=67, Label=Rollade Leon Osten, Category=null, Groups=[gLeon, gShutter, gUpperFloor, gEast])
2021-06-01 13:00:00.204 [INFO ] [org.openhab.core.model.script.shader] - last update  2021-06-01T12:59+02:00[Europe/Berlin]
2021-06-01 13:00:00.211 [INFO ] [org.openhab.core.model.script.shader] - difference 60208
2021-06-01 13:00:00.215 [INFO ] [org.openhab.core.model.script.shader] - --
2021-06-01 13:00:00.218 [INFO ] [org.openhab.core.model.script.shader] - item Bedroom_Shutter (Type=RollershutterItem, State=69, Label=Rollade Schlafzimmer, Category=null, Groups=[gBedRoom, gShutter, gUpperFloor, gEast])
2021-06-01 13:00:00.223 [INFO ] [org.openhab.core.model.script.shader] - last update  2021-06-01T12:59+02:00[Europe/Berlin]
2021-06-01 13:00:00.230 [INFO ] [org.openhab.core.model.script.shader] - difference 60227
2021-06-01 13:02:00.164 [INFO ] [org.openhab.core.model.script.shader] - --
All RollershutterItems did not change but the lastUpdate timestamp seems to be changed by the call of lastUpdate. What am I doing / understanding wrong?
<item>.lastUpdate is a call to your default persistence service. What’s that? When did it last persist that Item?
i.e, it is not necessarily when the Item itself was last updated, it’s when the database updated.
If you’ve got everything default, you’re probably looking at RRD4J persisting every minute.
thank you for the quick answer. I changed to a call of item.changedSince() to get some hysteresis and I did not realise that this was a function of Persistence.
