Bernd,
I can see the data coming in from the binding, but it doesn’t seem to be getting across to the Openhab UI (I can see it being stored as OPEN when it’s CLOSED - ie received command1 0x13.
Here is the latest log. device is 28,5C,D7. I see the command, but there is no corresponding publish. This only started last Thursday, I’m not sure what changed, but I have been changing network settings/rebooting and so on.
2015-10-18 23:30:46 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:28.5C.D7|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x11|command2:0x01|
2015-10-18 23:30:46 DEBUG o.o.b.i.i.d.MessageDispatcher[:68]- all link message: IN:Cmd:0x50|fromAddress:28.5C.D7|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x11|command2:0x01|
2015-10-18 23:30:46 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 28.5C.D7:GenericLastTime publishing: 2015-10-18T23:30:46
2015-10-18 23:30:47 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:28.5C.D7|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x11|command2:0x01|
2015-10-18 23:30:47 DEBUG o.o.b.i.i.d.MessageDispatcher[:68]- all link message: IN:Cmd:0x50|fromAddress:28.5C.D7|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x11|command2:0x01|
2015-10-18 23:30:47 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 28.5C.D7:GenericLastTime publishing: 2015-10-18T23:30:47
2015-10-18 23:30:47 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: GenericDimmer(1:3:8) OUT:Cmd:0x62|toAddress:13.4D.F9|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:30:47 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 500 msec, quiettime = 500
2015-10-18 23:30:47 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:13.4D.F9|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:30:48 DEBUG o.o.b.i.i.d.RequestQueueManager[:132]- device queue for 13.4D.F9 is empty!
2015-10-18 23:30:48 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:13.4D.F9|toAddress:2A.E7.67|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x01|command2:0xFF|
2015-10-18 23:30:48 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 13.4D.F9:GenericDimmer DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:30:48 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:13.4D.F9|toAddress:2A.E7.67|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x01|command2:0xFF|
2015-10-18 23:30:48 INFO o.o.b.i.i.d.MessageHandler[:472]- DimmerRequestReplyHandler: set device 13.4D.F9 to level 100
2015-10-18 23:30:48 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 13.4D.F9:GenericDimmer publishing: 100
2015-10-18 23:30:48 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 13.4D.F9:GenericDimmer set status to: QUERY_ANSWERED
2015-10-18 23:30:48 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 13.4D.F9:GenericLastTime publishing: 2015-10-18T23:30:48
2015-10-18 23:31:00 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: IOLincContact(1:1:4) OUT:Cmd:0x62|toAddress:2F.73.A5|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x01|
2015-10-18 23:31:00 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 1500 msec, quiettime = 500
2015-10-18 23:31:00 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:2F.73.A5|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x01|
2015-10-18 23:31:01 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:2F.73.A5|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0x00|
2015-10-18 23:31:01 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 2F.73.A5:IOLincContact DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:31:01 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:2F.73.A5|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0x00|
2015-10-18 23:31:01 INFO o.o.b.i.i.d.MessageHandler[:700]- ContactRequestReplyHandler: set contact 2F.73.A5 to: OPEN
2015-10-18 23:31:01 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 2F.73.A5:IOLincContact publishing: OPEN
2015-10-18 23:31:01 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 2F.73.A5:IOLincContact set status to: QUERY_ANSWERED
2015-10-18 23:31:01 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 2F.73.A5:GenericLastTime publishing: 2015-10-18T23:31:01
2015-10-18 23:31:02 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:31.A7.49|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x14|command2:0xFF|
2015-10-18 23:31:02 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 31.A7.49:GenericLastTime publishing: 2015-10-18T23:31:02
2015-10-18 23:31:02 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: IOLincSwitch(1:1:4) OUT:Cmd:0x62|toAddress:2F.73.A5|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:02 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 500 msec, quiettime = 500
2015-10-18 23:31:02 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:2F.73.A5|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:02 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:2F.73.A5|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0x00|
2015-10-18 23:31:02 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 2F.73.A5:IOLincSwitch DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:31:02 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:2F.73.A5|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0x00|
2015-10-18 23:31:02 INFO o.o.b.i.i.d.MessageHandler[:419]- SwitchRequestReplyHandler: set device 2F.73.A5 to OFF
2015-10-18 23:31:02 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 2F.73.A5:IOLincSwitch publishing: OFF
2015-10-18 23:31:02 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 2F.73.A5:IOLincSwitch set status to: QUERY_ANSWERED
2015-10-18 23:31:02 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 2F.73.A5:GenericLastTime publishing: 2015-10-18T23:31:02
2015-10-18 23:31:02 DEBUG o.o.b.i.i.d.RequestQueueManager[:132]- device queue for 2F.73.A5 is empty!
2015-10-18 23:31:07 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: GenericDimmer(1:3:8) OUT:Cmd:0x62|toAddress:38.82.76|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:07 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 500 msec, quiettime = 500
2015-10-18 23:31:07 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:38.82.76|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:07 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:38.82.76|toAddress:2A.E7.67|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x01|command2:0x00|
2015-10-18 23:31:07 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 38.82.76:GenericDimmer DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:31:07 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:38.82.76|toAddress:2A.E7.67|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x01|command2:0x00|
2015-10-18 23:31:07 INFO o.o.b.i.i.d.MessageHandler[:468]- DimmerRequestReplyHandler: set device 38.82.76 to level 0
2015-10-18 23:31:07 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 38.82.76:GenericDimmer publishing: 0
2015-10-18 23:31:07 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 38.82.76:GenericDimmer set status to: QUERY_ANSWERED
2015-10-18 23:31:07 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 38.82.76:GenericLastTime publishing: 2015-10-18T23:31:07
2015-10-18 23:31:08 DEBUG o.o.b.i.i.d.RequestQueueManager[:132]- device queue for 38.82.76 is empty!
2015-10-18 23:31:14 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: GenericDimmer(1:3:8) OUT:Cmd:0x62|toAddress:13.4D.6D|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:14 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 500 msec, quiettime = 500
2015-10-18 23:31:14 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:13.4D.6D|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:14 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:13.4D.6D|toAddress:2A.E7.67|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x02|command2:0xFF|
2015-10-18 23:31:14 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 13.4D.6D:GenericDimmer DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:31:14 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:13.4D.6D|toAddress:2A.E7.67|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x02|command2:0xFF|
2015-10-18 23:31:14 INFO o.o.b.i.i.d.MessageHandler[:472]- DimmerRequestReplyHandler: set device 13.4D.6D to level 100
2015-10-18 23:31:14 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 13.4D.6D:GenericDimmer publishing: 100
2015-10-18 23:31:14 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 13.4D.6D:GenericDimmer set status to: QUERY_ANSWERED
2015-10-18 23:31:14 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 13.4D.6D:GenericLastTime publishing: 2015-10-18T23:31:14
2015-10-18 23:31:14 DEBUG o.o.b.i.i.d.RequestQueueManager[:132]- device queue for 13.4D.6D is empty!
2015-10-18 23:31:14 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:13.4D.6D|toAddress:2A.E7.67|messageFlags:0x23=ACK_OF_DIRECT:3:0|command1:0x02|command2:0xFF|
2015-10-18 23:31:16 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:28.5C.D7|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x13|command2:0x01|
2015-10-18 23:31:16 DEBUG o.o.b.i.i.d.MessageDispatcher[:68]- all link message: IN:Cmd:0x50|fromAddress:28.5C.D7|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x13|command2:0x01|
2015-10-18 23:31:16 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 28.5C.D7:GenericLastTime publishing: 2015-10-18T23:31:16
2015-10-18 23:31:17 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:28.5C.D7|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x13|command2:0x01|
2015-10-18 23:31:17 DEBUG o.o.b.i.i.d.MessageDispatcher[:68]- all link message: IN:Cmd:0x50|fromAddress:28.5C.D7|toAddress:00.00.01|messageFlags:0xCF=ALL_LINK_BROADCAST:3:3|command1:0x13|command2:0x01|
2015-10-18 23:31:17 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 28.5C.D7:GenericLastTime publishing: 2015-10-18T23:31:17
2015-10-18 23:31:20 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: GenericDimmer(1:3:8) OUT:Cmd:0x62|toAddress:38.DA.D6|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:20 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 500 msec, quiettime = 500
2015-10-18 23:31:20 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:38.DA.D6|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:21 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:38.DA.D6|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0xFE|
2015-10-18 23:31:21 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 38.DA.D6:GenericDimmer DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:31:21 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:38.DA.D6|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0xFE|
2015-10-18 23:31:21 INFO o.o.b.i.i.d.MessageHandler[:472]- DimmerRequestReplyHandler: set device 38.DA.D6 to level 100
2015-10-18 23:31:21 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 38.DA.D6:GenericDimmer publishing: 100
2015-10-18 23:31:21 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 38.DA.D6:GenericDimmer set status to: QUERY_ANSWERED
2015-10-18 23:31:21 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 38.DA.D6:GenericLastTime publishing: 2015-10-18T23:31:21
2015-10-18 23:31:21 DEBUG o.o.b.i.i.d.RequestQueueManager[:132]- device queue for 38.DA.D6 is empty!
2015-10-18 23:31:27 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: GenericSwitch(1:1:6) OUT:Cmd:0x62|toAddress:25.33.A3|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:27 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 500 msec, quiettime = 500
2015-10-18 23:31:27 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:25.33.A3|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:28 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:25.33.A3|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0xFF|
2015-10-18 23:31:28 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 25.33.A3:GenericSwitch DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:31:28 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:25.33.A3|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0xFF|
2015-10-18 23:31:28 INFO o.o.b.i.i.d.MessageHandler[:422]- SwitchRequestReplyHandler: set device 25.33.A3 to ON
2015-10-18 23:31:28 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 25.33.A3:GenericSwitch publishing: ON
2015-10-18 23:31:28 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 25.33.A3:GenericSwitch set status to: QUERY_ANSWERED
2015-10-18 23:31:28 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 25.33.A3:GenericLastTime publishing: 2015-10-18T23:31:28
2015-10-18 23:31:28 DEBUG o.o.b.i.i.d.RequestQueueManager[:132]- device queue for 25.33.A3 is empty!
2015-10-18 23:31:34 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: GenericDimmer(1:3:8) OUT:Cmd:0x62|toAddress:34.CB.62|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:34 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 500 msec, quiettime = 500
2015-10-18 23:31:34 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:34.CB.62|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:34 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:34.CB.62|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0x00|
2015-10-18 23:31:34 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 34.CB.62:GenericDimmer DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:31:34 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:34.CB.62|toAddress:2A.E7.67|messageFlags:0x2B=ACK_OF_DIRECT:3:2|command1:0x00|command2:0x00|
2015-10-18 23:31:34 INFO o.o.b.i.i.d.MessageHandler[:468]- DimmerRequestReplyHandler: set device 34.CB.62 to level 0
2015-10-18 23:31:34 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 34.CB.62:GenericDimmer publishing: 0
2015-10-18 23:31:34 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 34.CB.62:GenericDimmer set status to: QUERY_ANSWERED
2015-10-18 23:31:34 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 34.CB.62:GenericLastTime publishing: 2015-10-18T23:31:34
2015-10-18 23:31:34 DEBUG o.o.b.i.i.d.RequestQueueManager[:132]- device queue for 34.CB.62 is empty!
2015-10-18 23:31:40 DEBUG o.o.b.i.i.device.InsteonDevice[:379]- qe taken off direct: GenericDimmer(1:3:8) OUT:Cmd:0x62|toAddress:13.4D.F3|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:40 DEBUG o.o.b.i.i.device.InsteonDevice[:399]- next request queue processed in 500 msec, quiettime = 500
2015-10-18 23:31:40 DEBUG o.o.b.i.internal.driver.Port[:382]- writing (500): OUT:Cmd:0x62|toAddress:13.4D.F3|messageFlags:0x0F=DIRECT:3:3|command1:0x19|command2:0x00|
2015-10-18 23:31:41 DEBUG o.o.b.i.InsteonPLMActiveBinding[:522]- got msg: IN:Cmd:0x50|fromAddress:13.4D.F3|toAddress:2A.E7.67|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x10|command2:0x00|
2015-10-18 23:31:41 DEBUG o.o.b.i.i.d.MessageDispatcher[:134]- 13.4D.F3:GenericDimmer DIRECT_ACK: q:QUERY_PENDING cmd: 80
2015-10-18 23:31:41 DEBUG o.o.b.i.i.d.MessageDispatcher[:139]- changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:13.4D.F3|toAddress:2A.E7.67|messageFlags:0x2F=ACK_OF_DIRECT:3:3|command1:0x10|command2:0x00|
2015-10-18 23:31:41 INFO o.o.b.i.i.d.MessageHandler[:468]- DimmerRequestReplyHandler: set device 13.4D.F3 to level 0
2015-10-18 23:31:41 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 13.4D.F3:GenericDimmer publishing: 0
2015-10-18 23:31:41 DEBUG o.o.b.i.i.d.MessageDispatcher[:159]- defdisp: 13.4D.F3:GenericDimmer set status to: QUERY_ANSWERED
2015-10-18 23:31:41 DEBUG o.o.b.i.i.device.DeviceFeature[:263]- 13.4D.F3:GenericLastTime publishing: 2015-10-18T23:31:41
2015-10-18 23:31:41 DEBUG o.o.b.i.i.d.RequestQueueManager[:132]- device queue for 13.4D.F3 is empty!
2015-10-18 23:32:07 INFO o.o.b.i.InsteonPLMActiveBinding[:603]- devices: 41 configured, 41 polling, msgs received: 108
