I just upgraded my running Openhab2 to the newest snapshot 2.1.0~20170203040910-1 .
I have been using the following syntax successfully for a while now:
Group label="Test" {
Switch item=Testitem1
Switch item=Testitem2
This gives me the opportunity to group items together which don’t belong to the same group, hence an easy way to create submenus in sitemaps.
Since the latest snapshot all sitemaps using this syntax stopped working; now I can’t define groups without defining an item for them like this:
Group label="Test" item=Testgroup {
Why is that? Have I been using groups wrong all the time?
This is the error groups without item definition produce:
rule ruleGroup failed predicate: {getUnorderedGroupHelper().canLeave(grammarAccess.getGroupAccess().getUnorderedGroup_1())}?
This is a fatal error which stops sitemaps containing such groups from working all together (quite a shock )
One can assign some dummy items to all groups of course, but I want to understand what lead to this change.
