How can i change the State of a contact item.
Window and door is closed but OH3 tells me open…
When i opened the Window/Door it tells me closed…
Thanks for help.
Thanks for help.
So the state is inverted. Take a look at the linked channel, maybe there is an option to change the behavior (depends on the addon)
Ok i found that option in Things > Channel > Configure Channel > than the switch “Invert State”
Thank you very much!
