I have been using the LCN binding for years and am very satisfied with it.
Since this week (I think with the update to OH3.4 M2) I have problems.
I get the following warnings in the log file:
S000M075: Failed to receive status message: LEDs and Logic: Failed finally after 3 tries
S000M110: Module did not respond to command: A1DI000000
S000M027: Failed to receive status message: Relays: Failed finally after 3 tries
S000M200: Module did not respond to command: R8–0-----
Relais & LED switching is no longer possible
What can be the cause? How can I fix the problem?
