I finally got my new Ledvance Smart+ Compact Outdoor Zigbee. I’m using OpenHAB 3 with BV 2010/10 using the Zigbee binding.
I tried pairing the device with OpenHAB, and that worked quite well – the device was found and the Switch channel was detected. However, when I change the status of the plug using the button on the side of the device, OpenHAB apparently receives no information on the status change. The device is shown as online until I try to change the status of the OpenHAB channel – at this point the device goes offline.
Here are the log entries I’m getting:
2022-05-16 22:45:43.539 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - F0D1B800001C4621: Starting ZigBee device discovery
2022-05-16 22:45:43.541 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zigbee:device:01382828:f0d1b800001c4621' to inbox.
2022-05-16 22:45:44.073 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - F0D1B800001C4621: Starting ZigBee device discovery
2022-05-16 22:45:43.542 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'zigbee:device:01382828:f0d1b800001c4621' has been added.
2022-05-16 22:45:49.649 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'zigbee:device:01382828:f0d1b800001c4621' has been removed.
2022-05-16 22:45:49.657 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01382828:f0d1b800001c4621' changed from UNINITIALIZED to INITIALIZING
2022-05-16 22:45:49.663 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01382828:f0d1b800001c4621' changed from INITIALIZING to UNKNOWN
2022-05-16 22:45:50.056 [INFO ] [penhab.event.FirmwareStatusInfoEvent] - Firmware status of thing zigbee:device:01382828:f0d1b800001c4621 changed to UNKNOWN.
2022-05-16 22:46:02.056 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01382828:f0d1b800001c4621' changed from UNKNOWN to ONLINE
2022-05-16 22:49:25.540 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Ulkopistorasia_ON_OFF_PLUG_IN_UNITSwitch' received command ON
2022-05-16 22:49:34.965 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01382828:f0d1b800001c4621' changed from ONLINE to OFFLINE
Any ideas why this is and how I could debug the problem? I get the feeling that this is some kind of compatibility issue with the device, not a malfunctioning device, but is there something I can do to try to fix this? Finding an outdoor plug was quite difficult, it seems to be pretty much the only model out there.
