Moxified
(Moxified)
March 12, 2017, 2:59pm
1
I can’t seem to find this anywhere. I use .left() and .right() in a couple of rules since OH 1. They seem to work in OH2 but designer claims the method doesn’t exist. I can’t seem to find the new functions for this.
postUpdate(NUM_DSC_Vender_Status, PANEL_MESSAGE.state.toString.left(3))
Oli
(Oliver Stenzel)
March 12, 2017, 3:09pm
2
Designer complains about a lot, but as long as your rules work don’t worry.
In some files i have loads of complaints in Designer but rules run OK.
Moxified
(Moxified)
March 12, 2017, 3:11pm
3
OK, That’s fine, I’m just trying to find anything that might cause my rules engine to lock up.
MDAR
February 8, 2019, 8:13am
4
Hi
Did anyone get an answer to this?
I have a rule that works perfectly, until the incoming string is more than 64 characters, then the recieving device just rejects the whole command.
Current rule
rule "Sonos to Velbus Memo text"
Item Sonos_Title changed
Velbus_memo_text.sendCommand(Sonos_Title.state)
Should something like this work? (In openHAB2 2.5 M1)
rule "Sonos to Velbus Memo text - Left 63"
Velbus_memo_text.sendCommand(Sonos_Title.state.toString.left(63))
rossko57
(Rossko57)
February 8, 2019, 9:51am
5
Have you tried it?
The original post was about OH Designer not recognizing the methods; I shouldn’t think you are using Designer.
MDAR
February 8, 2019, 9:54am
6
That’s an excellent observation.
I’m not using the designer (to be honest I don’t know what it is).
I’ll simply “try” what I’ve put here and see what happens…
“What’s the worst that can happen”, said the drunk parachute instructor…
vzorglub
(Vincent Regaud)
February 8, 2019, 10:01am
7
It was the old VS Code. It was an eclipse based openHAB editor,. It was good but never really worked as well as VS Code.
