hey guys. I’ve got the below rule that isn’t working. its got something to do with the > but yet the < work fine. can anyone offer any advice as to why its not working?
rule "Auto Solar Power Usage"
Item Inverter_Generation_Combined changed
createTimer(now.plusSeconds(15), [|
if (Inverter_1_Grid.state < -3000)
logInfo("Auto Solar Power Usage", "More than 3000w of power going to the grid. switching on hot water")
Hot_water_Element_2.sendCommand(OFF)
if (Inverter_1_Grid.state < -6000)
logInfo("Auto Solar Power Usage", "More than 6000w of power going to the grid switching on Spa heater")
Spa_Target_Temp.sendCommand(38.5)
if (Inverter_1_Grid.state > 1000)
logInfo("Auto Solar Power Usage", "Less than -1000w of power. switching OFF hot water")
Hot_water_Element_2.sendCommand(ON)
if (Inverter_1_Grid.state > 1000 && Spa_Target_Temp.state > 33)
logInfo("Auto Solar Power Usage", "Less than -1000w of power. switching Off Spa heater")
Spa_Target_Temp.sendCommand(33)
Yes, it’s a weirdness of rules language. DSL works out what actual operations to use for symbols like == or > based on the first object. In your example, that’s a state type object, which is a bit amorphous - string, numeric, switch?
Try ((yourItem.state as Number) > 99)
thanks @rossko57 , ive tried your suggestion above but its still not working. this is what it shows in the logs.
2020-12-24 12:05:09.788 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'TEST TOD Power.rules'
2020-12-24 12:05:11.250 [INFO ] [odel.script.Add Inverter Generation!] - inv1 1228.0
2020-12-24 12:05:11.255 [INFO ] [odel.script.Add Inverter Generation!] - inv2 868.0
2020-12-24 12:05:11.256 [INFO ] [odel.script.Add Inverter Generation!] - sum 2096.0
2020-12-24 12:05:11.990 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 1803 2020-12-24T12:05:11.988+13:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@353a28 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@10dc50f (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@7da432 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1e1b01c (conditionalExpression: false)
} ] threw an unhandled Exception:
at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:65) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:954) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:235) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:857) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:231) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1205) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1135) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:237) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:469) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:255) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy57417.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
2020-12-24 12:05:12.008 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 1803 2020-12-24T12:05:11.988+13:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
Caused by: java.lang.NullPointerException
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
2020-12-24 12:05:13.344 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 1804 2020-12-24T12:05:13.341+13:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
2020-12-24 12:05:13.361 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 1804 2020-12-24T12:05:13.341+13:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
... 1 more
Reading your error log, it looks like it has performed 3 if() in the timer code successfully and blown up at the fourth - the if() with more elements. Check your construction of that line, I can’t see it from here.
