I have both of these Z-Wave scene controllers. They are identical except the MRZ can be connected to a load for direct control of that load. I am currently playing with the M0Z.
https://groups.google.com/forum/#!topic/openhab/CyTSW7xiqyk
https://groups.google.com/forum/#!topic/openhab/7OTKrx-is3Q
The products are in the Zwave database and I have set the association groups.
I am attempting to link items to each of the 4 on/off scene buttons…
Below is the log output when I press the following sequence of buttons: Scene1-OFF, Scene1-ON, Scene2-OFF, Scene2-ON
2015-11-17 14:35:41.248 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 20 01 00 B7
2015-11-17 14:35:41.250 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:35:41.250 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:35:41.250 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 20 01 00 B7
2015-11-17 14:35:41.250 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 20 01 00 B7
2015-11-17 14:35:41.251 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 20 01 00
2015-11-17 14:35:41.251 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:35:41.251 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class BASIC
2015-11-17 14:35:41.251 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:74 ]- NODE 103: Received Basic Request
2015-11-17 14:35:41.251 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:78 ]- NODE 103: Basic Set sent to the controller will be processed as Basic Report
2015-11-17 14:35:41.251 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:107 ]- NODE 103: Basic report, value = 0x00
2015-11-17 14:35:41.251 [DEBUG] [b.z.i.protocol.ZWaveController:595 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2015-11-17 14:35:41.251 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-11-17 14:35:41.251 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 103: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
2015-11-17 14:35:41.251 [WARN ] [.z.internal.ZWaveActiveBinding:467 ]- NODE 103: No item bound for event, endpoint = 0, command class = BASIC, value = 0, ignoring.
2015-11-17 14:35:41.251 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2015-11-17 14:35:43.665 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:43.667 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:35:43.667 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:35:43.668 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:43.668 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:43.668 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 2C 02 00
2015-11-17 14:35:43.668 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:35:43.668 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class SCENE_ACTUATOR_CONF
2015-11-17 14:35:43.668 [DEBUG] [ApplicationCommandMessageClass:62 ]- NODE 103: Command class SCENE_ACTUATOR_CONF not found, trying to add it.
2015-11-17 14:35:43.668 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass:221 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF
2015-11-17 14:35:43.668 [ERROR] [ApplicationCommandMessageClass:75 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF (0x2c)
2015-11-17 14:35:46.555 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 20 01 FF 48
2015-11-17 14:35:46.558 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:35:46.558 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:35:46.558 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 20 01 FF 48
2015-11-17 14:35:46.558 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 20 01 FF 48
2015-11-17 14:35:46.558 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 20 01 FF
2015-11-17 14:35:46.558 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:35:46.558 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class BASIC
2015-11-17 14:35:46.558 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:74 ]- NODE 103: Received Basic Request
2015-11-17 14:35:46.558 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:78 ]- NODE 103: Basic Set sent to the controller will be processed as Basic Report
2015-11-17 14:35:46.558 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:107 ]- NODE 103: Basic report, value = 0xFF
2015-11-17 14:35:46.558 [DEBUG] [b.z.i.protocol.ZWaveController:595 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2015-11-17 14:35:46.559 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-11-17 14:35:46.559 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 103: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2015-11-17 14:35:46.559 [WARN ] [.z.internal.ZWaveActiveBinding:467 ]- NODE 103: No item bound for event, endpoint = 0, command class = BASIC, value = 255, ignoring.
2015-11-17 14:35:46.559 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2015-11-17 14:35:49.866 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:49.868 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:35:49.868 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:35:49.868 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:49.868 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:49.868 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 2C 02 00
2015-11-17 14:35:49.868 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:35:49.868 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class SCENE_ACTUATOR_CONF
2015-11-17 14:35:49.868 [DEBUG] [ApplicationCommandMessageClass:62 ]- NODE 103: Command class SCENE_ACTUATOR_CONF not found, trying to add it.
2015-11-17 14:35:49.869 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass:221 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF
2015-11-17 14:35:49.869 [ERROR] [ApplicationCommandMessageClass:75 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF (0x2c)
2015-11-17 14:35:51.984 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 20 01 00 B7
2015-11-17 14:35:51.986 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:35:51.987 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:35:51.987 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 20 01 00 B7
2015-11-17 14:35:51.987 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 20 01 00 B7
2015-11-17 14:35:51.987 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 20 01 00
2015-11-17 14:35:51.987 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:35:51.987 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class BASIC
2015-11-17 14:35:51.987 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:74 ]- NODE 103: Received Basic Request
2015-11-17 14:35:51.987 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:78 ]- NODE 103: Basic Set sent to the controller will be processed as Basic Report
2015-11-17 14:35:51.987 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:107 ]- NODE 103: Basic report, value = 0x00
2015-11-17 14:35:51.993 [DEBUG] [b.z.i.protocol.ZWaveController:595 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2015-11-17 14:35:51.993 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-11-17 14:35:51.993 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 103: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
2015-11-17 14:35:51.994 [WARN ] [.z.internal.ZWaveActiveBinding:467 ]- NODE 103: No item bound for event, endpoint = 0, command class = BASIC, value = 0, ignoring.
2015-11-17 14:35:51.994 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2015-11-17 14:35:55.293 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:55.295 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:35:55.295 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:35:55.295 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:55.295 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:35:55.295 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 2C 02 00
2015-11-17 14:35:55.295 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:35:55.295 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class SCENE_ACTUATOR_CONF
2015-11-17 14:35:55.295 [DEBUG] [ApplicationCommandMessageClass:62 ]- NODE 103: Command class SCENE_ACTUATOR_CONF not found, trying to add it.
2015-11-17 14:35:55.295 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass:221 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF
2015-11-17 14:35:55.295 [ERROR] [ApplicationCommandMessageClass:75 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF (0x2c)
2015-11-17 14:35:56.765 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 20 01 FF 48
2015-11-17 14:35:56.769 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:35:56.769 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:35:56.769 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 20 01 FF 48
2015-11-17 14:35:56.769 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 20 01 FF 48
2015-11-17 14:35:56.769 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 20 01 FF
2015-11-17 14:35:56.769 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:35:56.769 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class BASIC
2015-11-17 14:35:56.769 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:74 ]- NODE 103: Received Basic Request
2015-11-17 14:35:56.769 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:78 ]- NODE 103: Basic Set sent to the controller will be processed as Basic Report
2015-11-17 14:35:56.769 [DEBUG] [z.i.p.c.ZWaveBasicCommandClass:107 ]- NODE 103: Basic report, value = 0xFF
2015-11-17 14:35:56.769 [DEBUG] [b.z.i.protocol.ZWaveController:595 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2015-11-17 14:35:56.769 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-11-17 14:35:56.769 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 103: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2015-11-17 14:35:56.770 [WARN ] [.z.internal.ZWaveActiveBinding:467 ]- NODE 103: No item bound for event, endpoint = 0, command class = BASIC, value = 255, ignoring.
2015-11-17 14:35:56.770 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2015-11-17 14:36:00.075 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:36:00.077 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:36:00.078 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:36:00.078 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:36:00.078 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:36:00.078 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 2C 02 00
2015-11-17 14:36:00.078 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:36:00.078 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class SCENE_ACTUATOR_CONF
2015-11-17 14:36:00.078 [DEBUG] [ApplicationCommandMessageClass:62 ]- NODE 103: Command class SCENE_ACTUATOR_CONF not found, trying to add it.
2015-11-17 14:36:00.078 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass:221 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF
2015-11-17 14:36:00.078 [ERROR] [ApplicationCommandMessageClass:75 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF (0x2c)
2015-11-17 14:36:32.090 [DEBUG] [eController$ZWaveReceiveThread:1441]- Receive Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:36:32.093 [DEBUG] [eController$ZWaveReceiveThread:1365]- Receive queue ADD: Length=1
2015-11-17 14:36:32.093 [DEBUG] [b.z.i.protocol.ZWaveController:1123]- Receive queue TAKE: Length=0
2015-11-17 14:36:32.093 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:36:32.093 [DEBUG] [b.z.i.protocol.ZWaveController:1124]- Process Message = 01 09 00 04 00 67 03 2C 02 00 B8
2015-11-17 14:36:32.093 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 67 03 2C 02 00
2015-11-17 14:36:32.093 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 103: Application Command Request (ALIVE:DONE)
2015-11-17 14:36:32.093 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 103: Incoming command class SCENE_ACTUATOR_CONF
2015-11-17 14:36:32.093 [DEBUG] [ApplicationCommandMessageClass:62 ]- NODE 103: Command class SCENE_ACTUATOR_CONF not found, trying to add it.
2015-11-17 14:36:32.093 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass:221 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF
2015-11-17 14:36:32.094 [ERROR] [ApplicationCommandMessageClass:75 ]- NODE 103: Unsupported command class SCENE_ACTUATOR_CONF (0x2c)
