Hello, I successfully use LG TV, where I display, for example, Toast messages to children. However, I cannot use the Toast message to display the value of items when it is changed, please advise? Thank you
Here is a sample rule, when the hot water circulation is started, messages appear on the TV that in 5 minutes they should go for a bath. I would also like to transfer, for example, the time or temperature of the boiler
configuration: {}
triggers:
- id: “3”
configuration:
command: ON
itemName: GenericMQTTThingESP826604data_HotWater
type: core.ItemCommandTrigger
conditions: - inputs: {}
configuration:
itemName: TV_kids_Power
state: ON
operator: =
type: core.ItemStateCondition
actions: - inputs: {}
configuration:
command: Cirkulace vody puštěna, za 5 minut do vany kdo je na řadě!
itemName: LGTVkids_Toast
type: core.ItemCommandAction
Items with boiler is this
GenericMQTTThingESP8226602data_Boiler
I must be missing some syntax or something, but I can’t figure it out, thanks
