After a bug has been fixed in the LGTV binding, I don’t get an exception anymore when connecting to my TV.
I tried to insert some buttons to start LG apps from openhab, but the only result I get is the following log entry:
[ERROR] [binding.lgtv.internal.LgtvConnection] - envelope=null maybe not connected
Here’s the item definition:
String LGTVWZ_AppStart "Start" {lgtv="*:LGTVWZ:APP_EXECUTE"}
String LGTVWZ_AppStopp "Stopp" {lgtv="*:LGTVWZ:APP_TERMINATE"}
And here’s the sitemap:
Switch item=LGTVWZ_AppStart mappings=[YouTube=YouTube, LOVEFiLM=Prime]
Switch item=LGTVWZ_AppStopp mappings=[YouTube=YouTube, LOVEFiLM=Prime]
And idea what I could change to make this working?
Here’s the relevant logfile part:
2017-12-26 14:05:43.063 [DEBUG] [lgtv.lginteraction.LgTvMessageReader] - sendtohandlers remoteaddr=192.168.1.99 message=VOLUME_CURRENT=14
2017-12-26 14:05:43.069 [DEBUG] [ab.binding.lgtv.internal.LgtvBinding] - Received status update 'VOLUME_CURRENT=14' from ip 192.168.1.99 for deviceId LGTVWZ
2017-12-26 14:05:43.074 [DEBUG] [ab.binding.lgtv.internal.LgtvBinding] - Received status update 'VOLUME_CURRENT=14' from ip 192.168.1.99 for deviceId LGTVWZ
2017-12-26 14:05:43.080 [DEBUG] [ab.binding.lgtv.internal.LgtvBinding] - Received status update 'VOLUME_CURRENT=14' from ip 192.168.1.99 for deviceId LGTVWZ
2017-12-26 14:06:11.512 [ome.event.ItemCommandEvent] - Item 'LGTVWZ_AppStart' received command LOVEFiLM
2017-12-26 14:06:11.519 [DEBUG] [ab.binding.lgtv.internal.LgtvBinding] - Received command (item='LGTVWZ_AppStart', state='LOVEFiLM', class='class org.openhab.core.library.types.StringType')
2017-12-26 14:06:11.524 [DEBUG] [binding.lgtv.internal.LgtvConnection] - send to tv ip=192.168.1.99 command=APP_EXECUTE type=8 val=LOVEFiLM lgsendparam=
2017-12-26 14:06:11.528 [ERROR] [binding.lgtv.internal.LgtvConnection] - envelope=null maybe not connected
2017-12-26 14:06:11.562 [vent.ItemStateChangedEvent] - LGTVWZ_AppStart changed from YouTube to LOVEFiLM
2017-12-26 14:06:42.944 [DEBUG] [binding.lgtv.internal.LgtvConnection] - sendtotv: url=http://192.168.1.99:8080 typ=GET command=udap/api/data?target=volume_info s=
2017-12-26 14:06:42.981 [DEBUG] [binding.lgtv.internal.LgtvConnection] - <?xml version="1.0" encoding="utf-8"?><envelope><dataList name="Volume Info"><data><mute>false</mute><minLevel>0</minLevel><maxLevel>100</maxLevel><level>14</level></data></dataList></envelope>
2017-12-26 14:06:42.998 [DEBUG] [binding.lgtv.internal.LgtvConnection] - answer: <?xml version="1.0" encoding="utf-8"?><envelope><dataList name="Volume Info"><data><mute>false</mute><minLevel>0</minLevel><maxLevel>100</maxLevel><level>14</level></data></dataList></envelope>
P.S.: The pairing was successful:
2017-12-26 13:44:34.357 [INFO ] [binding.lgtv.internal.LgtvConnection] - lgtv connectionstatus of ip=192.168.1.99 changed from CS_NOTCONNECTED to CS_PAIRED
2017-12-26 13:44:34.453 [INFO ] [binding.lgtv.internal.LgtvConnection] - sendpairkey with result=200 successconnectionstatus=CS_PAIRED
