i have inbarked on a new yuarny .
i want to create my rules in openhab. use to run some on node red. do to the lack of knoladge on how to do rules. in text form.
so what i want to do is:
i have a porch light that i want to have turn on on sun set and off at sun rise.
my Rule :
rule "Sun set Light"
Channel 'astro:sun:home:set#event' triggered START
item Kitchen_Light.sendCommand(ON)
rule "Sun Rise Light"
Channel 'astro:sun:home:rise#event' triggered START
item Kitchen_Light.sendCommand(OFF)
But there is where i get stuck.
it is a Sonnoff T1 3 Gang.
the one is the porch light.
So my problem comes in here:
1)i want to still be able to turn it on and off by the switch
(if light is turned on by the rule,i want to be able to turn it off by the switch or via openhab and it stays off.or vice versa.) on node red with big timer if i turn it off at the switch it just turns back on.
What must i do to get it to work this way ?
Kind regards
Bad syntax.
If you look in your openhab.log you will probably find an error report from when it tried to read your rules file after it was last edited.
You just want
The rules as shown will turn on the light at sunset and turn it off at dawn.
Anything else you do to it in between those moments will not be affected by these rules.
The rules only do something at the instant they are triggered. They don’t do anything in between times.
If you change the light in between times, the rules still don’t do anything.
Obviously, you would need to have the Astro binding installed.
You would need an Astro sun type Thing called “home”, because that is what you specified in your rule.
You would need to wait for sunup or sunrise for anything to happen. You should see the event in your events.log
You would need to have a valid rules file loaded, your openhab.log will tell you if that happened.
If your rules are still as simple as the broken versions you showed before, you should be able too see if they act by looking in your events.log for commands issued.
Ok So i re thougth the whole controll and i implemanted DP time of Day.
Got that working for me. now i whant to use that to turn the light on and off.
rule "Stoep Light On"
Item vTimeOfDay == Evening
Kitchen_Light_Stoep.sendCommand(ON)
rule "Stoep Light Off"
Item vTimeOfDay == Bed
Kitchen_Light_Stoep.sendCommand(OFF)
Does the syntex look right ?
then my second part is i want to have it look to my alarm also.
if my alarm is disarmed or armed-Away or Armed-Stay and it is Evening it must turn the light on
when armed stay and tod is Bed then turn off.
if armed away and tod changes to bed the light must stay on. only turn off when tod changes to morning.
Item vTimeOfDay == Evening &
Item Alarm_Status == Disarmed or
Item Alarm_Status == Armed-Away or
Item Alarm_Status == Armed-Stay
Item vTimeOfDay changed to "Evening" &
Item vTimeOfDay changed to "Bed" &
rule "Stoep Light Off Morning"
Item vTimeOfDay changed to "Morning" &
Nope. You’ve seen no examples of this, and cannot just make it up.
All that can go in the “when” triggers section is events.
Think through the implications - if there were such a thing as a “AND” trigger, you would need two events to occur in the exact same microsecond.
So, separate out the events that you want to trigger your rule, from the state conditions that you want to be true.
Example -
if ( Alarm_Status.state == "Armed-Stay" ) {
// do stuff
I miss understood the rule system.
i am currently moving my rules from node red as it is a lot more work to get a simple rule to work on it. i will need to sharpen up my rule writing. thank you for pointing out my problem.
i understood it like i would write plc code.
as example. item 1 and item 2 or item 3 or item 4 (as plc code.)
but with Openhab it is a triger and then conditions.
item 1 Changes.
if condition 1 is met. then do this and so on.
will go through the rule documents again. with this view.
Ok Now. if i write it this way .it seems i am still wrong somewhere.
My Rule
if (Item Alarm_Status == "Disarmed") {
Kitchen_Light_Stoep.sendCommand(ON) }
if ( Item Alarm_Status == "Armed-Away" ) {
if ( Item Alarm_Status == "Armed-Stay" ) {
Kitchen_Light_Stoep.sendCommand(OFF) }
if ( Item Alarm_Status == "Disarmed" ) {
sendBroadcastNotification("Stoep Light Still On" + " - " + now.toString("MM/dd HH:mm ")) }
rule "Stoep Light Off Armed"
In my Log:
2020-05-16 16:12:26.448 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'Outlight.rules' has errors, therefore ignoring it: [7,6]: no viable alternative at input 'Item'
[7,11]: missing ')' at 'Alarm_Status'
[7,43]: mismatched input ')' expecting 'end'
[21,7]: no viable alternative at input 'Item'
[21,12]: missing ')' at 'Alarm_Status'
[21,47]: mismatched input ')' expecting 'end'
[32,7]: no viable alternative at input 'Item'
[32,12]: missing ')' at 'Alarm_Status'
[32,47]: mismatched input ')' expecting 'end'
Thank you.
i did change it to state. right after i send the reply.
it seems to be working now. tonight i am studing the rule document . i want to be able to get all my rules right first time.
