another “problem” I still have:
I’m creating a few lights control rules right now.
But if I create now a rule, which is to reach in the morning, and the lamp which is to be switched on in the morning when deploying is active, this is switched off, since this rule is not currently “true”.
Can I solve this with a RBE node?
I created something here:
[{"id":"7d7eb6f7.ebcf6","type":"openhab2-in","z":"5fb544a8.383a7c","name":"","controller":"ce8959a.db84d28","itemname":"Stube_Bewegungsmelder_Motion","x":215,"y":101,"wires":[["f3e10da1.278b6"],[]]},{"id":"4e4e4264.9a7e14","type":"bigtimer","z":"5fb544a8.383a7c","outtopic":"0","outpayload1":"true","outpayload2":"false","name":"Morgens Flur Lampe","lat":"53.3056","lon":"7.7512","starttime":"345","endtime":"480","startoff":"+5","endoff":"0","offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":"","month6":"","d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":"","w6":"","xday1":"0","xmonth1":"0","xday2":"0","xmonth2":"0","xday3":"0","xmonth3":"0","xday4":"0","xmonth4":"0","xday5":"0","xmonth5":"0","xday6":"","xmonth6":"","xd1":"0","xw1":"0","xd2":"0","xw2":"0","xd3":"0","xw3":"0","xd4":"0","xw4":"0","xd5":"0","xw5":"0","xd6":"","xw6":"","suspend":false,"random":false,"repeat":false,"atstart":true,"odd":false,"even":false,"x":192,"y":203,"wires":[["582782c3.8574ac"],[],[]]},{"id":"f3e10da1.278b6","type":"change","z":"5fb544a8.383a7c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"motion","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"ON","fromt":"str","to":"true","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"OFF","fromt":"str","to":"false","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":492,"y":94,"wires":[["582782c3.8574ac"]]},{"id":"582782c3.8574ac","type":"BooleanLogic","z":"5fb544a8.383a7c","name":"","operation":"AND","inputCount":2,"topic":"result","x":570,"y":206,"wires":[["6a8d8aa7.625204","29060308.db358c","bcd593e0.a5aed"]]},{"id":"6a8d8aa7.625204","type":"BDebug","z":"5fb544a8.383a7c","name":"Debug","x":753,"y":45,"wires":[]},{"id":"b14b5976.0b9ec8","type":"debug","z":"5fb544a8.383a7c","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":985,"y":103,"wires":[]},{"id":"29060308.db358c","type":"change","z":"5fb544a8.383a7c","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"ON","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"OFF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":789,"y":206,"wires":[["b14b5976.0b9ec8","cde339a3.d7c2e8"]]},{"id":"dd27dce.ea7482","type":"openhab2-out","z":"5fb544a8.383a7c","name":"","controller":"ce8959a.db84d28","itemname":"Stube_HM_kleine_Lampe_State","topic":"ItemCommand","payload":"","x":1122,"y":206,"wires":[[]]},{"id":"bcd593e0.a5aed","type":"debug","z":"5fb544a8.383a7c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":750,"y":106,"wires":[]},{"id":"cde339a3.d7c2e8","type":"rbe","z":"5fb544a8.383a7c","name":"","func":"rbei","gap":"","start":"","inout":"out","property":"payload","x":924,"y":289,"wires":[["dd27dce.ea7482","a8a4c770.54c118"]]},{"id":"a8a4c770.54c118","type":"debug","z":"5fb544a8.383a7c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1139,"y":296,"wires":[]},{"id":"ce8959a.db84d28","type":"openhab2-controller","z":"","name":"openhab2","protocol":"http","host":"localhost","port":"8080","path":"","username":"","password":""}]
Regards
Hermann
