I have 3 dimmer lights. These lights are in a Group. I display the group as the master controls (SWITCH and SLIDER). I also display the dimmer item as a switch for easy on off. I also display the individual lights dimmer item in the sitemap as a switch and a dimmer.
This works fine until I turn one of the lights off. At which point the group dimmer is now Off even though the other lights are now on.
How can I make the group report that the others are still on, or do I have this setup wrong?
Group:Dimmer Bedroom_Light_Brightness "Bedroom Light" <light> (gBedroom) [ "Lighting" ]
Group:Dimmer Bedroom_Light_ColorTemp "Bedroom Light Colour Temperature" <light> (gBedroom) [ "Lighting" ]
Dimmer Bedroom_Light1_Brightness "Bedroom Light 1" <light> (gBedroom, Bedroom_Light_Brightness)
Dimmer Bedroom_Light1_ColorTemp "Bedroom Light 1 Colour Temperature" <light> (gBedroom, Bedroom_Light_ColorTemp)
Dimmer Bedroom_Light2_Brightness "Bedroom Light 2" <light> (gBedroom, Bedroom_Light_Brightness)
Dimmer Bedroom_Light2_ColorTemp "Bedroom Light 2 Colour Temperature" <light> (gBedroom, Bedroom_Light_ColorTemp)
Dimmer Bedroom_Light3_Brightness "Bedroom Light 3" <light> (gBedroom, Bedroom_Light_Brightness)
Dimmer Bedroom_Light3_ColorTemp "Bedroom Light 3 Colour Temperature" <light> (gBedroom, Bedroom_Light_ColorTemp)
Text label="Bedroom" icon="light" {
Switch item=Bedroom_Lamp
Switch item=Bedroom_Light_Brightness label="Bedroom Light"
Slider item=Bedroom_Light_Brightness label="Bedroom Light Brightness [%.1f %%]"
Slider item=Bedroom_Light_ColorTemp label="Bedroom Light Color Temperature [%.1f %%]"
Text label="Individual Lights" icon="light" {
Switch item=Bedroom_Light1_Brightness label="Bedroom Light 1"
Slider item=Bedroom_Light1_Brightness label="Bedroom Light 1 Brightness [%.1f %%]"
Slider item=Bedroom_Light1_ColorTemp label="Bedroom Light 1 Color Temperature [%.1f %%]"
Switch item=Bedroom_Light2_Brightness label="Bedroom Light 2"
Slider item=Bedroom_Light2_Brightness label="Bedroom Light 2 Brightness [%.1f %%]"
Slider item=Bedroom_Light2_ColorTemp label="Bedroom Light 2 Color Temperature [%.1f %%]"
Switch item=Bedroom_Light3_Brightness label="Bedroom Light 3"
Slider item=Bedroom_Light3_Brightness label="Bedroom Light 3 Brightness [%.1f %%]"
Slider item=Bedroom_Light3_ColorTemp label="Bedroom Light 3 Color Temperature [%.1f %%]"
Text item=Bedroom_Light_RemoteControlBatteryLevel label="Bedroom Remote Battery level [%d %%]"
I’ve tried Group:Dimmer:OR(ON:OFF) but this means the slider won’t work as its either 0% or 100%
Hope this makes sense. Any suggestions?
Chris
