I have been using Openhab for several years with no issues. I have several rules set up that trigger the light switches in the house to turn on or off. Earlier this year, the rules became less reliable. The light switches do not always go on or off when they are supposed to. Here is an example from the logs:
2022-04-17 19:44:00.006 [INFO ] [openhab.event.ChannelTriggeredEvent ] - astro:sun:local:set#event triggered START
2022-04-17 19:44:00.042 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'BackEaveSwitch_Switch' received command ON
2022-04-17 19:44:00.054 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'CornerEavesSwitch_Switch' received command ON
2022-04-17 19:44:00.064 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LowerStairsSwitch_Switch' received command ON
2022-04-17 19:44:00.072 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'BackEaveSwitch_Switch' predicted to become ON
2022-04-17 19:44:00.081 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'CornerEavesSwitch_Switch' predicted to become ON
2022-04-17 19:44:00.088 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LowerStairsSwitch_Switch' predicted to become ON
2022-04-17 19:44:00.097 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BackEaveSwitch_Switch' changed from OFF to ON
2022-04-17 19:44:00.098 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LowerStairsSwitch_Switch' changed from OFF to ON
2022-04-17 19:47:00.002 [INFO ] [openhab.event.ChannelTriggeredEvent ] - astro:sun:local:set#event triggered END
The “Corner Eaves Switch” received the command to turn on, was predicted to turn on and then never turns on. The other two switches do. It is not always this switch that fails to turn on. It seems to be random which switch fails to change and sometimes no switches fail. This happens with switches in other rules as well.
I haven’t made any changes to the system, other than installing several Z Wave wall plugs, that I later unplugged and disabled in Openhab several months ago. At first I thought maybe this impacted the Z Wave network connections that the devices make to one another but I’ve read that the network automatically rebuilds itself. I’m not sure what to do to fix this other than wipe the system and start over which I really don’t want to have to do. Any thoughts or help would be appreciated!
- Platform information:
- Hardware: Raspberry Pi
- OS: Openhabian
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 3.1.0
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
