A simple list widget that controls a simple light switch. The current state of the light is represented by the icon and toggle’s color: yellow for on, gray for off.
Hey Rich - Finally getting around to making a UI … your widgets are nice … I haven’t spent much time to understand how to code them … but quick question, I see you have a Battery Level Widget that uses a group … can the same thing be dont to control a list of lights? I’m assuming that could make the list more compact than just adding cells for each light?
It’s a little specific to my setup though because it hides and shows different switches based on the state of an Item so that it includes the Christmas lights only while I have them up. And even that isn’t perfect because it requires “Christmas” to be in the Item label.
Make sure to reload MainUI after making the changes. Also, changes to a custom widget placed on a Layout page need to be removed and readded to that Layout page to pick up the changes.
I have just tried this widget and if I test the widget in the developer tools it works fine, but when I import the widget to the display page, I can configure the title and item, but the widget is invisible.
I do not see any log message I can link to the problem. I run openhabian with OH3.2
Do I need to install something special?
EDIT: I have realised that I need to add list and then add the widget in the list
