fixed the buttons it now brings the following error.
@s73ven
Having created the buttons i can see on the logs the error shown above so I have tried previous config files (thats the Lw_Baseā¦) and no change.
there are two switches added which can be triggered from HABPanel but returns the error mentioned above
@delid4ve I managed to get my whole house polling on Version 1 now. I cut down the amount of stuff Iām polling for by reducing it to only what I need OpenHAB to be aware of for automation purposes. So Iām only polling for switch status, dimmer level, power and energy for all devices and outlet in use for sockets. I also stopped polling for power and energy for my Gen 1 devices as they donāt report it anyway so itās a wasted effort. By doing all that I reduced the number of items in the curl by about a third which let me add my remaining devices in. My response time from LWRF API is down to 7 or 8 seconds and I donāt get any structure not found errors at all.
Alex i waited to use the new rules file you sent until i added some more devices, i have now setup using the new rules file and all seems OK except the temp and target temp are not displaying the figures and i see this line in the openlab log
[ng.exec.internal.handler.ExecHandler] - An exception occurred while formatting the command line with the current time and input values : āFormat specifier ā%2$sāā
Do you see anything similar in your setup?
Are any of the values updating? DimLevel on your switches etc?
Just checked and If I use the physical switch or lightwave app then Openhab doesnāt reflect the current state
Ok, let me check the file, make sure I didnāt break anything
Has openhab got permission to run scripts?
I had to add permissions on my system, have a google.
Just waiting on lw to get back to me as was Xmas shutdown, hopefully will be soon.
Yes Iāve been running the V2 version for about 3 months, only changed the rules file to add the thermostat and boiler switch which @xela added recently while also adding a few news devices.
Make sure you havenāt changed the json for the feature checking script
It has to be exactly as was, think 1st feature on line 1 with the rest of the argument, then each feature on a new line after that.
If itās ANY different it will not work. Thatās the only part that needs to be formatted exactly as my rule creates it
Still getting this on the log whilst trying to trigger the configuration.
16:58:04.359 [WARN ] [.rest.core.internal.item.ItemResource] - Received HTTP POST request at āitems/Lw_Setupā with an invalid status value āā.
If i change the value to ON on the switch the following happens
17:42:25.444 [INFO ] [smarthome.event.ItemCommandEvent ] - Item āLw_Setupā received command ON
The buttons (setup / update) are created under the /etc/openhab2/items and the rule file has been created on both the /rules/ and /scripts/.
There is no LWR devices showing, any suggestions?
You have put your username / password in at the top and have configured the paths for your system?
Ok,
Exec binding installed?
Openhab has permissions to run scripts?
@delid4ve
The exec binding is installed
and the /etc/script and /etc/rules have been set to chmod 777 at the moment.
So this is when you run the initial setup yes?
I remember someone posting that I forgot to change a couple of the paths to the variables, donāt know if I changed it and uploaded the files, have a look down the setup files and look for any hard coded paths.
Sorry not at a pc atm and trying to get issues sorted where Iāve upgraded to 2.5 (Zwave )
ok i am running v2.5
should the file be on /etc/openhab2/scripts or /etc/openhab2/rules
just for clarification.
What file?
Lw_Base.rules should be in rules folder
ok thats where it is
Just looking at my file in my system and itās got hard coded paths where it says //define things file line 64
Have a look and let me know
Donāt know if I replaced my system file though from my server
If so replace this block:
//Define Things File
var String RulesFile = "Thing exec:command:LwAuth [ command=\\\"%2\\$s\\\", interval=3600,timeout=5, autorun=true ]\r\n" +
"Thing exec:command:LwGet [ command=\\\"sh " + OpenHabScriptsPath + "Lw_Get.sh %2\\$s\\\", interval=6,timeout=6, autorun=true ]\r\n" +
"Thing exec:command:LwUpdate_Structures [ command=\\\"sh " + OpenHabScriptsPath + "Lw_Update_Structures.sh %2\\$s\\\", interval=0,timeout=1000, autorun=true ]\r\n" +
"Thing exec:command:LwUpdate_Features [ command=\\\"sh " + OpenHabScriptsPath + "Lw_Update_Features.sh %2\\$s\\\", interval=0,timeout=1000, autorun=true ]\r\n" +
"Thing exec:command:LwUpdate [ command=\\\"sh " + OpenHabScriptsPath + "Lw_Update.sh %2\\$s\\\", interval=0,timeout=1000, autorun=true ]\r\n"
//Create Things File
