LightwaveRF Binding Updated
Sorry i just realized that i’m running on docker and the root ca are not installed :slight_smile: is it possible to add an option to disable ssl verification ? On the script based version of lightwaverf i had to modify manualy and add the “-k” option on curl
you got the latest version from git?
I have literally just uploaded a new version 1.0.7 (deleted old ones too so no one gets wrong one)
Version 1.0.7
  • Fixed bug with Update listener not reflecting the correct polling time
  • Removed Update Listener additional Thread as was unstable
  • Added synchronization lock for handle command - status will now stay in sync.
@xela @Fixer
mmm.. you got me.
Ill have to have a look and integrate (will be an option)
Add it to git as a feature request
I have uploaded the certificate and i still have the same issue, i’ll enable more debugs to check
After updating my openhab docker to 2.5.1 and Binding to 1.0.8 i get the below
[WARN ] [.lightwaverf.internal.UpdateListener] - Start Lightwave Login Process
[WARN ] [.lightwaverf.internal.UpdateListener] - Lightwave Rf Servers Currently Down
[WARN ] [rf.internal.handler.LWAccountHandler] - Channel List For Updating Is Empty
dont think it can connect to the net.
that comes up when login fails (http request returns a 404 not found)
Really weird as everything else is okay, Alexa binding etc
Is the certificate you loaded still there? could you have loaded it wrong?
Wrong password :rofl:
Well at least it’s an easy fix :smiley:
@delid4ve does the http request return a different error for that, maybe able to catch it?
What version were you running, going to spin up a docker with an older version to confirm I get the same
Now i’m running openhab 2.5.1 stable
What were you running when you had the first errors
2.5 stable ( 2.5.0-armhf-debian ) and 1.0.6 binding
If it helps anyone, I’ve repurposed some of @delid4ve 's original script to dump your LWRF structure and other info into the log. I’ve found this helpful several times when trying to diagnose various issues:
rule "Get LWRF Structure"
Item LWRF_Test_Switch received command ON
logInfo("LWRF-TEST.rules", "Rule Started")
logInfo("LWRF-TEST.rules", "Authentication Started")
var String username = "xxxxxxx@example.com"   // Your LWRF username goes here
var String password = "yourpassword"          // Your LWRF password goes here
val Get_Token = executeCommandLine("curl@@-X@@POST@@https://auth.lightwaverf.com/v2/lightwaverf/autouserlogin/lwapps@@-H@@Content-Type: application/json@@-H@@x-lwrf-appid: ios-01@@-d@@{\"email\" : \"" + username + "\",\"password\" : \"" + password + "\"}",5000)
        var String RefreshToken = transform("JSONPATH", "$.refresh_token" , "{" + Get_Token.substringBetween("\"tokens\":{","}}") + "}")
        var String AccessToken =  transform("JSONPATH", "$.access_token" , "{" + Get_Token.substringBetween("\"tokens\":{","}}") + "}")
Refresh_Token.postUpdate(RefreshToken)
Access_Token.postUpdate(AccessToken)
logInfo("LWRF-TEST.rules", "Refresh Token - " + RefreshToken)
logInfo("LWRF-TEST.rules", "Access Token - " + AccessToken)
logInfo("LWRF-TEST.rules", "Authentication Finished")
Thread::sleep(3000)
logInfo("LWRF-TEST.rules", "Structure Dump Started")
var String Structure_GET = executeCommandLine("curl@@-s@@-g@@-XGET@@https://publicapi.lightwaverf.com/v1/Structures@@-H@@Authorization:bearer " + AccessToken,5000)
var String Structure_Value = transform("JSONPATH", "$.structures" , Structure_GET)
var Structures_GET = executeCommandLine("curl@@-s@@-X@@GET@@https://publicapi.lightwaverf.com/v1/Structure/" + Structure_Value + "@@-H@@Authorization:bearer " + AccessToken,20000)
var Devices_Count = Integer::parseInt(transform("JSONPATH","$.devices.length()", Structures_GET).toString)
logInfo("LWRF-TEST.rules", "Structures - " + Structure_Value)
logInfo("LWRF-TEST.rules", "My Structure - " + Structures_GET)
logInfo("LWRF-TEST.rules", "Device Count - " + Devices_Count.toString)
logInfo("LWRF-TEST.rules", "Structure Dump Finished")
logInfo("LWRF-TEST.rules", "Rule Finished")
Items:
Switch LWRF_Test_Switch
String Refresh_Token
String Access_Token
